![]() | Home > Technical (L322) > L322 difficult to fill with fuel |
TrevCOSS Member Since: 05 Jan 2020 Location: Plymouth Posts: 31 ![]() ![]() |
They are fitted with a wrong fuel block function, it’s listed in the manual, there is a reset tool in with the spare wheel, possibly this |
Gazcw Member Since: 11 Jan 2020 Location: Northampton Posts: 172 ![]() ![]() ![]() |
Unnecessary quote removed
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 ![]() ![]() ![]() |
I've had this too. Thought it was full, I always do a few clicks of the pump. Turned out to only be three-quarters. |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 ![]() ![]() ![]() |
I've had that but strangely only when using supermarket fuel ? |
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 545 ![]() ![]() ![]() |
Strangely I've now had both of the Fatty's do this and it's at the local Shell station. I've done all the usual turning the nozzle around etc. and it helps but doesn't cure it. The wrong fuel block function hasn't been triggered on either car. I'm going to fill up elsewhere next time to see if it's the pumps. It's still perfectly possible to brim the tank, but it takes a long time and it's annoying. Drives:
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 ![]() ![]() |
I have the same. Was told on the forum it´s just one of the pleasures of RR ownership.
I just filled my Fatty up at a different Shell station, no problems. I'm begining to suspect it might by to do with the auto shut off mechanism on some fuel delivery nozzles being far more sensitive than others. Drives:
MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140 ![]() ![]() ![]() |
this also happens on my disco 2,
