Home > Technical (L322) > L322 difficult to fill with fuel
rvbush
United Kingdom 2011 Range Rover Vogue TDV8 Stornoway Grey
Odd one this, although it could have been a faulty fuel pump. Problem was that the pump kept cutting out as if the tank was full, except it was nowhere near full. Is there a vent or something for the tank that could get partially blocked which might cause the pressure in the tank to increase and trip the fuel pump nozzle? Drives:
2010 FFRR TdV8 Vogue - Stornoway Grey
2010 FFRR TdV8 Vogue SE - Zermatt Silver
1998 BMW E36 M3 GTII
Post #544471 19th Feb 2020 9:25pm
TrevCOSS
They are fitted with a wrong fuel block function, it’s listed in the manual, there is a reset tool in with the spare wheel, possibly this
Post #544473 19th Feb 2020 9:32pm
Gazcw
United Kingdom 2011 Range Rover Vogue TDV8 Baltic Blue
Re: L322 difficult to fill with fuel
Unnecessary quote removed
I had the same issue. Guys on here said to turn nozzle upside down. Did a full tank yesterday without issue. 2011 4.4tdv8 Vogue
Baltic Blue
Post #544474 19th Feb 2020 9:36pm
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
I've had this too. Thought it was full, I always do a few clicks of the pump. Turned out to only be three-quarters.
Post #544489 19th Feb 2020 10:37pm
Henda
United Kingdom 2006 Range Rover Vogue TDV8 Zambezi Silver
I've had that but strangely only when using supermarket fuel ? Thumbs Up
Post #544504 19th Feb 2020 11:43pm
rvbush
Strangely I've now had both of the Fatty's do this and it's at the local Shell station. I've done all the usual turning the nozzle around etc. and it helps but doesn't cure it. The wrong fuel block function hasn't been triggered on either car. I'm going to fill up elsewhere next time to see if it's the pumps. It's still perfectly possible to brim the tank, but it takes a long time and it's annoying. Drives:
Post #544525 20th Feb 2020 8:56am
jackie-o
Netherlands
I have the same. Was told on the forum it´s just one of the pleasures of RR ownership.
You could look into a faulty fuel gauge sensor. The problem is well documented if you search on the forum.
My car always showed about 20 litres more than was actually in it and so it would cut of the pump early. RR Vogue 4.4 TDV8 - 11
Toyota Land Cruiser Prado - 02
LR Discovery 4 SDV6 -11 - Gone
RR Vogue 3.6 TDV8 - Gone
Post #544543 20th Feb 2020 12:17pm
rvbush
I just filled my Fatty up at a different Shell station, no problems. I'm begining to suspect it might by to do with the auto shut off mechanism on some fuel delivery nozzles being far more sensitive than others. Drives:
Post #544548 20th Feb 2020 12:34pm
MattHughes86
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
this also happens on my disco 2,
sometimes its down to the pump been to powerful and then it shuts off, sp,etimes they are just to sensitive.
i find if it keeps happening fill at half speed for a little bit
matt If In Doubt Give It A Clout
Previous Vehicles:
Land Rover 110 3.5 V8 (is my dads though)
1.9TD Seat Toledo
1.4 Rover 214 (dont ask)
2.0 Nissan Primera SLX (i want it back)
1.4 Seat Ibiza
996cc Toyota Aygo (I miss this car???)
04 TD5 Discovery 2 (my Current Car)
07 4.2 SC FF (wifes car)
Post #544560 20th Feb 2020 2:47pm
