Home > Technical (L322) > instrument menu button |
alfapat Member Since: 09 Apr 2017 Location: Elgin Posts: 349 |
It just doesn’t work / replicate on the dash , nothing. How do I get it to show even time , distance , mpg etc.
16th Feb 2020 10:04pm |
dazza1983 Member Since: 19 Feb 2019 Location: southampton, hampshire Posts: 529 |
it sounds as if either your dash is faulty or the button then buddy?
17th Feb 2020 9:48am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7802 |
I think if you don’t have anything set to come up, it shows everything, though I appreciate ive not worded that the best..... by default, everything is shown.
17th Feb 2020 10:17am |
17th Feb 2020 10:31am |
So if you have the ignition on and press and hold the end of the stalk and nothing comes up on the centre display, I’d try disconnecting the battery for a few min to see if it resets. I’m stuck after that.
17th Feb 2020 10:35am |
Thank you for your assistance , I have seen these pages in the book I will disconnect the battery and try again with setting steering immediately afterwards , I have seen the display more than a year ago but not now.
17th Feb 2020 12:11pm |
No change , I’m wandering I have inadvertently altered any CCF values. Trouble is they are not available to see on GapIID tool either ...... oh hell! |
17th Feb 2020 10:09pm |
Might need Navcoder, though I think the IID tool takes a backup the first time you plug it in, so the guys at Gap might be able to help? Might be worth asking them....
17th Feb 2020 11:07pm |
Had to refresh the Gap tool last night , now after plugging in it asks for ign on, not only on the mobile interface but on the car as well , so have been advised to check the diagnostic plug.
18th Feb 2020 8:23am |
After a word with Gap support who have very helpful it looks like my ign barrel may be the culprit. Apparently a common problem with that age of L322. So maybe draining the battery if it’s faulty.
19th Feb 2020 12:56pm |
Moved on a bit here, tonight after pulling fuses for the diagnostic and instrument panel reset the Gap tool and saw the led change colour and bong the instrument panel lost the instruction to turn the ign on.
19th Feb 2020 11:05pm |
