Home > Technical (L322) > Another odd starting fault?
Tight777
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
Every now and then, key in ignition, turn on, I get radio etc but no dash lights and car won’t start.
It seems worse if the car is warm, new battery about 6 months ago, it just happened at home and
I tried a booster to see if low voltage was the cause but no still a dead dashboard.
10 mins later all is well and it started.
Any thoughts?
Post #543884 14th Feb 2020 11:10am
gotters
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Santorini Black
There are a lot of threads on this across the internet, and I recently suffered exactly this issue.
Cold starts fine, warm starts after about 40m driving while the car still warm were usually a fail, then after 20-30 presses of the button the car would fire up.
Over the months I had a new battery (didn't solve it) new starter (didn't solve it) before my main dealer agreed to take it back in and fix on their £££ as admitted they hadn't solved it.
After a few days of their top lead tech driving the car home and seeing the problem they traced it to high resistance in a main fuse in the car which was quite dirty, they cleaned it up and the problem hasn't re-occured in 2 months for me (so fingers crossed).
I'm no expert but believe the electrics on these cars are very complex and a bit flakey, so the issue may not always be the same when a similar starting problem is exhibiting itself.
See you aren't far from me in Epping - it was Bishops Stortford main dealer that got to the bottom of this for me.
Post #544057 16th Feb 2020 6:08am
Tight777
Thanks I’ll look for that, any idea where it is?
Post #544059 16th Feb 2020 7:28am
gotters
nope sorry, no idea
but they were tracing thru the whole wiring loom looking for high resistance as suspected that was what was causing the start fails - says to me that the starting problems you can see discussed in many places are a variety of things, not a single fix.
Post #544066 16th Feb 2020 8:42am
