Home > Technical (L322) > EBD / ABS / Stability control fault
joel-h
England 2010 Range Rover Vogue TDV8 Ipanema Sand
Hi everyone,
I had my 2010 L322 TDV8 serviced by Rovertune 2 weeks ago and a new AGM battery and tow bar with all electrics fitted.
I have used the car with no issues for my daily station run (only 5 mins each way) with no issues many times since. I did a longer trip, about 20 mins each way at the weekend, again with no issues.
Today (2 deg C so cold) I turned on the ignition and had a number of warnings flash up:
EBD fault
ABS fault
No stability control -drive with care
May have been more than that - quite a few lights on. Anything to try / check before I take it to my local garage?
Driving to the Alps on Feb 14th, need it working properly for that!!
Cheers,
Joel
Post #543083 5th Feb 2020 10:53am
MattHughes86
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
check that its charging properly,
ccheck that its also holding amps and volts correctly.
then im out of ideas
Matt If In Doubt Give It A Clout
Previous Vehicles:
Land Rover 110 3.5 V8 (is my dads though)
1.9TD Seat Toledo
1.4 Rover 214 (dont ask)
2.0 Nissan Primera SLX (i want it back)
1.4 Seat Ibiza
996cc Toyota Aygo (I miss this car???)
04 TD5 Discovery 2 (my Current Car)
07 4.2 SC FF (wifes car)
Post #543094 5th Feb 2020 12:57pm
alternator, loose battery clamp.. ... - .- -.
Post #543100 5th Feb 2020 2:05pm
joel-h
Thanks guys - got back to the station today and it hasn't done it again, so fingers crossed whatever it was has fixed itself. Will check tightness of battery connections
Post #543122 5th Feb 2020 5:32pm
Tooltime79
Worth checking for breaks on the wires going to the top of the shock absorbers in the engine bay. They control the active dynamics which can cause errors like this (I think was standard from 2010). Have you got a diagnostic tool to read error codes?
Post #543140 5th Feb 2020 7:34pm
briangunn
United Kingdom 2010 Range Rover Vogue SE TDV8 Buckingham Blue
Check the fusible link 'board' behind the battery. My facelift TDV8 had a complete fit a few times and it was related to a lightly 'fretted' connection on one of the fusible links that fed the ABS amongst other circuits.
Unbolted all of the links, cleaned up all of the terminals and used some contact grease and the problem hasn't returned..
Post #543155 5th Feb 2020 8:54pm
