![]() | Home > Technical (L322) > EBD / ABS / Stability control fault |
MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140 ![]() ![]() ![]() |
check that its charging properly,
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35485 ![]() ![]() |
alternator, loose battery clamp.. ... - .- -.
joel-h Member Since: 23 Sep 2018 Location: Kent Posts: 35 ![]() ![]() ![]() |
Thanks guys - got back to the station today and it hasn't done it again, so fingers crossed whatever it was has fixed itself. Will check tightness of battery connections |
Tooltime79 Member Since: 03 Jun 2015 Location: York, North Yorkshire Posts: 27 ![]() ![]() ![]() |
Worth checking for breaks on the wires going to the top of the shock absorbers in the engine bay. They control the active dynamics which can cause errors like this (I think was standard from 2010). Have you got a diagnostic tool to read error codes? |
briangunn Member Since: 19 May 2019 Location: London Posts: 56 ![]() ![]() ![]() |
Check the fusible link 'board' behind the battery. My facelift TDV8 had a complete fit a few times and it was related to a lightly 'fretted' connection on one of the fusible links that fed the ABS amongst other circuits.
