Home > Maintenance & Mods (L322) > Help - confused by H7 lamps just bought :(
DMRR
Hi,
I bought some GreenClick H7 LED Car Headlight Bulbs 44W 8000LM LED for my 2009 Westminster - I can't see how to fit them. I only bought them because they were recommended on here. They are the ones with the tails.
Anyone shed any light (no pun intended) or I'll have to send them back for a refund Sad
If required I can supply a picture. Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #542635 1st Feb 2020 12:19pm
jim4244
England 2005 Range Rover Vogue Td6 Zambezi Silver
Are these for the main beam?
Jim
Post #542666 1st Feb 2020 4:45pm
they would be yes... ... - .- -.
Post #542672 1st Feb 2020 5:41pm
DMRR
Anyone? Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #543093 5th Feb 2020 12:50pm
Weegie
This video might be of assistance:
It's a bit slow at the start showing the bulbs in every aspect Sad but if you advance to the actual fitting it should become clear.
Not an RR and 6000 but that doesn't matter. I do agree if you just get them without foreknowledge it isn't all that clear what to do.
HTH John
GAP iiD BT
Post #543097 5th Feb 2020 1:58pm
is it not like replacing a normal H7 bulb. ... - .- -.
Post #543098 5th Feb 2020 2:03pm
Have you a pic of what your trying to fit sir?
Post #543101 5th Feb 2020 2:05pm
DMRR
These Smile
https://www.amazon.co.uk/gp/product/B01MRQ...&psc=1 Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #543102 5th Feb 2020 2:10pm
DMRR
No - if it was I'd have had it done in a jiffy Smile Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #543103 5th Feb 2020 2:14pm
Am i right in thinking your lamps just push in on a late model 322 high beam? So, they don't have any spring clips you need to mechanically fix... Just push them in the holes... Thumbs Up
Post #543104 5th Feb 2020 2:15pm
DMRR
It's a 2009 - the original H7 is on a complicated "fishtail" which you turn to remove. The "locking" bit seems to be part of that and the original H7 plugs directly into it Sad Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #543107 5th Feb 2020 2:17pm
its not this mounting ring that you are referring to,
Post #543108 5th Feb 2020 2:26pm
DMRR
Hi Stan,
No - that's for the Xenon. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #543109 5th Feb 2020 2:27pm
ah..sorry i cant remember what the H7 holder looks like, any chance of a pic.. ... - .- -.
Post #543110 5th Feb 2020 2:29pm
I’ve just had a look at a 2009> facelift lamp and the high beam bulb just pushes into a holder! It’s dead simple...
Post #543132 5th Feb 2020 6:42pm
