Home > Technical (L322) > Passenger door lock
Fridström
Sweden 2007 Range Rover Vogue TDV8 Stornoway Grey
Passenger door lock
Hi
Need a bit of advice on my 2007 FFRR Smile
I took my passenger door lock out for a lube up, due to the problem of lock freezing.. And when I put it back in the car the lock dosent work, it works manually but not by the keayfob or the button in the dash. Everything else works fine in the door. All the other doors work.
Tried to disconnect the battery no change, bought a brand new lock from LR same problem.
Anyone had the same problem?
Post #542148 28th Jan 2020 2:29pm
fenlander
England 2002 Range Rover SE 4.4 V8 Tonga Green
Do you have access to a diagnostic tool eg GAPIIDTool?
It is possible you may have an electrical short circuit. "Gloria" 2002 L322 Voguish V8 LPG - carcass
"Jessica" 1996 Disco 1 300 TDi Auto
"Harriet" 1994 Disco 1 300 TDi Manual - Gone
"Daisy" 1992 Disco 1 200 TDi Manual - Gone
Post #542209 29th Jan 2020 1:30am
