Home > Technical (L322) > Air Suspension Problem
stewart1981
United Kingdom 2004 Range Rover Vogue Td6 Cairns Blue
I'm having a bit of a nightmare with the air suspension on my Range Rover L322 TD6.
Two weeks ago i got the air suspension / hdc inactive message on the dash and the next morning it had dropped to the deck.
I'm fortunate in having a diagnostics code reader and the only fault it was showing was code 50 Can Bus Fault.
I've since checked all the air bags for leaks, the ride height sensors individually and the pump, they all are fine.
On start up the pump runs for a around a minute and then cuts out with a hiss, as if back pressure is cutting it out / turning it off.
The suspension lock button light is constantly lit and no matter what i do it wont go off and i cant get the can bus error to clear either, i think this is somehow preventing the suspension from lifting.
I've a gut feeling that the issue is something electrical rather than mechanical.
Has anyone experienced anything similar or anything else to check / possible solutions?
Thanks for any help in advance.
Regards
Stewart
Post #542137 28th Jan 2020 12:10pm
