Home > Technical (L322) > Water ingress battery drain. |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Tailgate seal, rear space vents or bungs. etc.
25th Jan 2020 6:27pm |
ianr63 Member Since: 26 Oct 2017 Location: Cheltenham Posts: 13 |
My 53 plate had water ingress and i traced it back to the rear Quater side screen, stripped out the trim on the left hand side to get good access to the window, hose pipe on the outside and after a short while water was creeping in, i used some windscreen sealer along the bottom edge and up the front edge (applied on the inside) !
28th Jan 2020 10:19am |
bleeperman Member Since: 01 Nov 2012 Location: lancs and Anglesey Posts: 109 |
Thanks looks like a job for a dry day! |
28th Jan 2020 3:12pm |
