Home > Technical (L322) > Water ingress battery drain.
bleeperman
2014 Range Rover Vogue SDV8 Balmoral Blue
Gloves off today guys, crackling speakers sent me to amp in n/s rear. Wet and wild. Ripped the lot out and barrowed it all to the barn to dry out. Checked the remote unlock cassette rx and this too is u/s! Where is all the water coming from?
Post #541876 25th Jan 2020 4:49pm
rjff
Tailgate seal, rear space vents or bungs. etc.
Have a search for
water ingress
lots on that Shocked Cheers
Richard
Gap IIDBT
Post #541887 25th Jan 2020 6:27pm
ianr63
United Kingdom 2007 Range Rover Autobiography Black TDV8 Santorini Black
My 53 plate had water ingress and i traced it back to the rear Quater side screen, stripped out the trim on the left hand side to get good access to the window, hose pipe on the outside and after a short while water was creeping in, i used some windscreen sealer along the bottom edge and up the front edge (applied on the inside) !
this has cured my water ingress.
tailgate rubber is very common fault, i changed this prior to the above.
Post #542126 28th Jan 2020 10:19am
bleeperman
Thanks looks like a job for a dry day!
Post #542155 28th Jan 2020 3:12pm
