Home > In Car Electronics (L322) > Charging points for 2011 tdv8 battery?
Dolphinboy
United Kingdom 2015 Range Rover Autobiography SDV8 Baltic Blue
Just tried to top up my battery with a charger after sitting a few days in the cold, but it won’t charge by putting the leads directly into the pos and net terminals of the battery. It’s just sitting at 11.8 volts.
Is there somewhere else I should be connecting to? (My 2004 v8 petrol had a pos and neg bolt in front of the battery itself.)
Post #541653 23rd Jan 2020 8:29pm
Bradders
United Kingdom 2012 Range Rover Westminster TDV8 Zermatt Silver
Red lead to the positive battery terminal and the black to un unpainted bit of chassis. I connect mine to one of the unpainted strut bolts. Current: FF Westminster money pit
Gone:
RRS 4.2 SC
RRS 3.6 TDV8
FL2 TD4
Post #541655 23rd Jan 2020 8:40pm
Baltic Blue
I have one of these Ctek leads permanently wired to the battery cable in the rear fuse box cubby. and a convenient earth bolt next to it.
It takes seconds to plug in the charger.
Post #541661 23rd Jan 2020 9:12pm
Think it maybe a problem with your charger James?
Post #541671 23rd Jan 2020 9:52pm
Fox889
One assumes your charger has enough amperage?
I used an intelligent charger but found it hadn't enough ooomph to charge a large battery, used a c-tek & no worries.
Worth thinking about. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #541677 23rd Jan 2020 10:37pm
Dolphinboy
Thanks everyone for your advice. Charger works fine on both my other cars. Think it may be the neg pole which is not allowing a charge to go through. I will look for an unpainted bolt to attach to.
Cheers all.
Post #541679 23rd Jan 2020 10:42pm
fenlander
England 2002 Range Rover SE 4.4 V8 Tonga Green
On my 2002 V8 petrol/LPG, I really like the "reverse charge via towbar electrics" method - assuming you have a 13 pin fitting (I believe one of the 7 pin varieties also works) see https://www.disco3.co.uk/shop/tow-electric...c-p45.html
Post #541688 23rd Jan 2020 11:49pm
Cheers all.
The NEG point from the pre 07MY is still on the top of the passenger strut on your 2011MY James...
Post #541693 24th Jan 2020 12:38am
DrRob
Craig - can I confirm my understanding that the negative terminal on a 2011 tdv8 grounds onto the passenger side strut ? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #541698 24th Jan 2020 7:31am
DrRob yes-ish sir! The battery won’t solely ground there sir but I believe (from memory) the ground stud has never been removed in later models... Does that answer your question?
Post #541702 24th Jan 2020 8:29am
At 11.8V it's possible a smart charger wouldn't detect it is connected to a battery and so not start the charge process.
Seen it happen. What you need initially is an old fashioned non smart charger to get the voltage up a bit so that you can then connect your charger.
Post #541711 24th Jan 2020 9:20am
Dolphinboy
Thanks again all. Success! Used the same nut (photo to follow) as on previous models only there’s no neg wire running to it.
The only Censored was getting the clip onto the pos terminal. There’s not a lot of room within the battery section! Is there a live pos nut on the bulkhead I could have used as in previous models?
Post #541715 24th Jan 2020 10:30am
No James, they took the + peg away when Ford owned them sir... Rolling Eyes
Post #541722 24th Jan 2020 12:39pm
Dolphinboy
Thanks Craig Thumbs Up
Post #541728 24th Jan 2020 2:07pm
Post #541730 24th Jan 2020 2:22pm
