Home > In Car Electronics (L322) > Charging points for 2011 tdv8 battery? |
Bradders Member Since: 03 Dec 2018 Location: Gods own country Posts: 417 |
Red lead to the positive battery terminal and the black to un unpainted bit of chassis. I connect mine to one of the unpainted strut bolts. Current: FF Westminster money pit
23rd Jan 2020 8:40pm |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3778 |
I have one of these Ctek leads permanently wired to the battery cable in the rear fuse box cubby. and a convenient earth bolt next to it.
23rd Jan 2020 9:12pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16300 |
Think it maybe a problem with your charger James? |
23rd Jan 2020 9:52pm |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 693 |
One assumes your charger has enough amperage?
23rd Jan 2020 10:37pm |
Dolphinboy Member Since: 07 Dec 2009 Location: Bristol Posts: 3176 |
Thanks everyone for your advice. Charger works fine on both my other cars. Think it may be the neg pole which is not allowing a charge to go through. I will look for an unpainted bolt to attach to.
23rd Jan 2020 10:42pm |
fenlander Member Since: 14 Jan 2020 Location: Norfolk Posts: 124 |
On my 2002 V8 petrol/LPG, I really like the "reverse charge via towbar electrics" method - assuming you have a 13 pin fitting (I believe one of the 7 pin varieties also works) see https://www.disco3.co.uk/shop/tow-electric...c-p45.html |
23rd Jan 2020 11:49pm |
The NEG point from the pre 07MY is still on the top of the passenger strut on your 2011MY James... |
24th Jan 2020 12:38am |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4307 |
Craig - can I confirm my understanding that the negative terminal on a 2011 tdv8 grounds onto the passenger side strut ? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
24th Jan 2020 7:31am |
DrRob yes-ish sir! The battery won’t solely ground there sir but I believe (from memory) the ground stud has never been removed in later models... Does that answer your question? |
24th Jan 2020 8:29am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3978 |
At 11.8V it's possible a smart charger wouldn't detect it is connected to a battery and so not start the charge process.
24th Jan 2020 9:20am |
Thanks again all. Success! Used the same nut (photo to follow) as on previous models only there’s no neg wire running to it.
24th Jan 2020 10:30am |
No James, they took the + peg away when Ford owned them sir... |
24th Jan 2020 12:39pm |
Thanks Craig |
24th Jan 2020 2:07pm |
24th Jan 2020 2:22pm |
