Home > Maintenance & Mods (L322) > Klunking noise in the engine bay upon cold startup in my 4.2
Page 3 of 4 <1234>
friskydog
Supercharger got collected today so will update as soon as testers have finished tolerance testing. 🙂 Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #545256 26th Feb 2020 9:08pm
friskydog
I was also advised that the solid coupler could potentially make a noise so I understand it wouldve been the original coupler replacement used. But we shall see once they have tested. Updates coming. Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #545257 26th Feb 2020 9:11pm
friskydog
Ah hah we have a little more progress...
"Initial look at the blower shows us that it’s overall looking fine, but that there is play in one of the rear bearings which is enough to cause knocking."
Monday it's to be stripped and completely inspected so fingers crossed all goes well. Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #545520 29th Feb 2020 8:10am
kezbo1981
United Kingdom 2006 Range Rover Vogue SE 4.2 SC V8 Buckingham Blue
That's good. Did they do the snout rebuild Originally?
Post #545561 29th Feb 2020 2:04pm
friskydog
This was the original report a few months back.
"The supercharger has passed inspection, this means the core components are acceptable for rebuild.
The report highlighted that the rotor pack is in very good condition, the case bearings are badly worn leading to overheating on one of the rotor shafts. The snout appears to be fine, it’s not the quietest as it has age but it isn’t ready to fail. This would get replaced as a matter of coarse during a rebuild anyway. We did find that the coupler has a crack, it’s quite common to see a crack of about 3mm on the inner face that’s not a problem. Yours however has propagated through to the drive pin bores, further progression will be to the outer wall at which point it will fail. This will require changing in addition to the rebuild." Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #545595 29th Feb 2020 4:37pm
friskydog
So we have liftoff.
The supercharger has been rebuilt and is now back in the car. So far so good apart from half the coating on the rotors has come off. Don't quite know why unless the knocking was the rotors catching since the first rebuild.
Here is a link to the video once the supercharger was back on.
Post #548484 27th Mar 2020 11:08pm
kezbo1981
Great! Is this the second time they have rebuilt the supercharger or was the coupler the only thing replaced last time?
Post #548485 27th Mar 2020 11:20pm
friskydog
Its the second rebuild. To be fair to them they did the rebuild again all free of charge. I am just glad to get my car back and running
Just cant bloomin test drive it due to all this essential travel limitations. Just my luck lol. Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #548486 27th Mar 2020 11:50pm
kezbo1981
That's good news, but bad no test drive! I've very similar noises coming from mine so suspect will be doing the same soon.
Post #548516 28th Mar 2020 9:00am
MattHughes86
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
i feel your pain.
i have a hose to replce on ours then i can test drive. the hose and car at work!!!!
Matt If In Doubt Give It A Clout
Previous Vehicles:
Land Rover 110 3.5 V8 (is my dads though)
1.9TD Seat Toledo
1.4 Rover 214 (dont ask)
2.0 Nissan Primera SLX (i want it back)
1.4 Seat Ibiza
996cc Toyota Aygo (I miss this car???)
04 TD5 Discovery 2 (my Current Car)
07 4.2 SC FF (wifes car)
Post #548544 28th Mar 2020 1:12pm
friskydog
so just to relay that my engine has been really quiet since the supercharger rebuild. The garage also renewed the warranty unfortunately coz we are in lockdown I still cant drive it to fully test. However on the positive the car is back together everything (soooo far) is looking and sounding good. Cant wait to get out for a proper long drive and see how she is. Appreciate all the pointers that you gave have messaged. I have just (pain on rust 15) POR'd my rear wheel arches for extra protection and in this current climate will be PORing my rear subframe as well. Thanks again all and all the best. Smile Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles
Post #549763 9th Apr 2020 11:47am
dhallworth
I’ve just bought a 2007 car that’s doing exactly the same thing so have a few questions I’m afraid!
Who was it that did the work on your Supercharger?
Did they give you a reason for that knocking noise?
What was the cost of the rebuild?
I’m quite happy to rebuild mine myself but want to make sure I get a kit with everything in it. Although, if it’s going to be a right pain in the arse of a job I’ll send them the whole unit.
David 2002 4.6 Vogue SE - Alveston Red with Lightstone Leather
Post #578323 3rd Jan 2021 11:22pm
Danwilderspin
Me again Smile not wishing to comment on every post of yours but this clunking sound are you also having a rough idle or misfiring? I had the same issue when I had a dirty idle its almost like the supercharger was spinning nicely and then the brakes were ut on momentarily, effectively shaking it.when I sorted the running the issue disappeared, although I don't think it was this but did the s/c oil too... Current stable:
2006 BMW M6
2007 4.2 V8 S/C FF
Gone:
2002 4.4 V8 FF
Post #578367 4th Jan 2021 10:05am
dhallworth
After changing my coil, the car is idling perfectly thankfully.
The noise on mine is barely audible and is probably just me being incredibly picky but I like them to be just right. I'm hoping to get the belt off later this evening and check that it's not present with the charger disconnected to be sure.
Post #578376 4th Jan 2021 10:59am
dhallworth
Friskydog, is your supercharger still silent after the 2nd rebuild?
The noise on mine is identical to yours and I’m curious as to what was replaced the 2nd time around that wasn’t replaced on the original rebuild.
I’d like to do mine myself but need to make sure I get the right parts.
Post #581016 25th Jan 2021 2:23am
Page 3 of 4 <1234>
