![]() | Home > Maintenance & Mods (L322) > Klunking noise in the engine bay upon cold startup in my 4.2 |
kezbo1981 Member Since: 20 Jan 2015 Location: Evesham, Worc Posts: 334 ![]() ![]() ![]() |
You can rule out dodgy oil then, assuming the level is ok. |
MattHughes86 Member Since: 01 Jun 2019 Location: Gloucestershire Posts: 140 ![]() ![]() ![]() |
our used to make a similar noise when cold or ticking over.
friskydog Member Since: 16 May 2018 Location: West Midlands Posts: 76 ![]() ![]() ![]() |
Got the car back from Mechanic and he couldn't find the issue. I dont know what to try next. Maybe I should buy the idler(s) for supercharger as drive belt changed and all Tensioners/Idlers attached were checked without issue.
Easy to test, take the belt off and start the engine. If noise has gone the problem is related to the 'charger, belt or idlers. If the noise is still there you are wasting money on those parts. |
I will go back to Farage and just ask them to test just that for now. Thanks Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles |
Ok all bit of an update.
Surely this is good news, you have isolated the sound to something linked with the supercharger and not the internals of the engine. Spinning the supercharger did not sound great, kindof gravelly. When you had it rebuilt was it the whole charger or just the snout and bearings in that? Was oil put back in the snout when reassembled? Do you have a guarantee on the rebuild? |
So indeed confirmation of where the problem lies is a step forward. I am sending the supercharger for a check over with the company that rebuilt last year in the hope it's something repairable.
brad s1 Member Since: 23 Sep 2008 Location: Boston Posts: 134 ![]() ![]() |
There is nothing spring loaded in that blower. Based on the vids my guess is they may have reused the superchargers snout coupler. It is a plastic disk with 6 holes. The shaft from the snout side of the blower has 3 prongs that slide into it, the gear/rotor 1/2 of the blower has another 3 pins which slide into the other 3 holes. The coupler joins the rotating halves of the blower once assembled. The vid showing the play points to this as the root cause. If it is worn you'll have play in the snout pulley before the gears actually grab.
also just in-case you do replace this part yourself... note the blower is actually 3 sections... the snout, the body housing the rotors and rear needle bearings and a gear housing sandwiched between the two. If you remove the snout it has ledges on it to pry it away from the center section. It is important you do not remove the center section from the rear, otherwise you'll have to completely separate all 3 parts, clean surfaces and then make a new gasket seal in two places instead of just one (the snout). It's also possible it you remove the rotors, the rear needle bearings will lose their seating and or grease. The rotors are pressed up in the middle section and ride on a couple of bearings, best not to remove the middle unless you're doing a full rebuild. Once the middle comes out, it sort of makes sense to replace all the bearings etc as things can lose their alignment/lubrication |
Really appreciate the time you have taken to reply.I will review and if brave enough I will follow your instruction. Many thanks for the valuable info. Top man. Range Rover Vogue SE 2007 L322 4.2 Supercharged 121k. Engine rebuilt @ 120666 Miles |
Google snout coupler and I'm sure there are step by step how to vids. Good luck. |
The original coupler in these is spring loaded - plastic shell with metal spring loaded tabs. I would be really surprised if powerhouse didn't insert a solid plastic coupler when rebuilding it, but you never know! Of interest, I changed the coupler to a solid one and the snout bearings last summer but the engine or blower is making a similar noise to those in the video clips. I wonder if there is an issue with the solid coupler or bearings being sold. |
@friskydog any update on this? |
