![]() | Home > Technical (L322) > 2011 TDV8 - How to remove handbrake module |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3823 ![]() ![]() ![]() |
It’s a 9 page PDF in the Workshop Manual, which is available free in the Wiki, but I think the answer may be “ NO “.
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
If it's the same as the 2007 then the rear sub frame needs to be dropped or atleast it did when my indie changed mine. 2015 4.4 AB
RichM63 Member Since: 10 Jul 2019 Location: Brittany Posts: 249 ![]() ![]() ![]() |
We did my 07 EPB cables as part of a complete rear end renovation at the end of the year.
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2279 ![]() ![]() ![]() |
I did mine on a 2007 and dropped the subframe and removed the entire exhaust as it is one piece lots of work but just needs to be plodded through |
My exhaust was not cut either, my module had stopped working completely so no choice but to change ,indie ( 2 off them ) did it in about 4 hours BUT I had to replace a few bolts , nuts etc. 2015 4.4 AB
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
I had to have mine replaced recently and it cost a fortune. I still don't get the point of an epb other than to cause problems. 2010 4.4 TDV8 Vogue SE |
