![]() | Home > Technical (L405) > Remote tailgate, should the lower open? |
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 360 ![]() ![]() |
When you press the button on the fob or the one under the dash is the lower tailgate supposed to open with the upper?
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
on mine and when locked ,you press the tailgate button on the fob and both power and upper open...you have to use the fob to close unless you 'unlock' whilst the back is open.
.....and, it seems like whether locked or unlocked the only way to open both upper and lower tailgate is to use the fob... ... - .- -.
The more I read the more I think it should be opening. I'm not convinced anything is faulty. It seams more likely that something isn't enabled.
mugsnstuff Member Since: 22 May 2012 Location: liverpool Posts: 6 ![]() ![]() ![]() |
I have wondered about this also! My FOB only open the top tailgate, i have to use the button on the lower tailgate itself to open that yet BOTH will close with one touch of the button on the keyfob |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 793 ![]() ![]() ![]() |
MY19 - both open only with the fob or by wiggling the foot under the bumper. If the dash switch or the tailgate button are pressed - only the upper part. |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
MY15 fob - upper and lower , dash button - upper only, you can close both via the fob or tailgate button. 2015 4.4 AB
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16312 ![]() ![]() ![]() |
Its an age related upgrade... 13/14/14.5MY's do NOT allow top & lower tailgate opening im afraid... Yet another thing the 15MY cars improved on... |
Hmmmmm |
The issue is canbus protocol! 2013-2014.5 have very different canbus to 2015-2017 for example! So, itโs only possible if the boot opening can messages are interpretable?
Interesting!!! I like silly little issues like this, will have to look into it as at the end of the day the fob sends a signal to the car to open the boot, canbus thinks,,,,, I know ! I am a mere 2013 model, I will send a signal to open just the upper boot, that will do ! I see no reason why the system can not be told to send the open boot signal to both the upper and lower tailgate to they BOTH open ?!? (may need to tap into the lower tailgate button with a few wires and a bit of solder to a relay picking up a live feed trigger from the upper boot module..... but could work !
horse86 Member Since: 09 Dec 2014 Location: PA Posts: 863 ![]() ![]() ![]() |
Disagree...Mines a 2014 AB and the top and bottom indeed Both open with a press of the key fob 2014 FF Autobiography 5.0 SC 2008 FFRR (sold) 2008 BMW M5 |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3757 ![]() ![]() |
Maybe for the American market ? 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
gibbo37 Member Since: 03 Sep 2012 Location: Swindon Posts: 19 ![]() ![]() ![]() |
Or maybe a 15MY ? |
