Home > Maintenance & Mods (L405) > Illuminated tread plate retrofit
Felstmiester
England 2015 Range Rover Vogue TDV6 Santorini Black
Loads of people have said the cables are there already. Was going to buy a set advertised on here. Just took one of my tread plates off and can’t see any wires or plugs under carpet ?
Post #540575 14th Jan 2020 4:40pm
JCW
They’re tucked away and not immediately obvious, mine had a sort of blanking plug fitted to each connector which you need to remove.
From memory, the front door ones are located under the carpet / foam around the base of the B pillar.
Post #540576 14th Jan 2020 4:58pm
Felstmiester
JCW. Your bang on. They’re are reasonably hidden away. Kind of expected them to be more centre of the tread plates for some reason.
For those who may have the same issue in the future
Post #540579 14th Jan 2020 6:12pm
