![]() | Home > Technical (L322) > Auxiliary coolant pump & FBH |
Nathan v8 Member Since: 04 Dec 2019 Location: South Wales Posts: 15 ![]() ![]() ![]() |
You could try back filling the fbh through the top hose inlet.
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 ![]() ![]() ![]() |
I'll try again tomorrow. I didn't put the heater on full last time. If that doesnt work I'll start pulling hoses and messing about.
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 ![]() ![]() ![]() |
Sounds like solid progress |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2943 ![]() ![]() ![]() |
I really need to get mine fixed 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 751 ![]() ![]() |
Andy,
Yes. Although it’s not as frequent as it was. 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
Hi all
That’s the same problem I had that sound is the coolant boiling in the fbh..
I've not had chance to try it yet but I'll swap the polarity round, hopefully it'll sort it.
Swapped the wiring round. All sorted! I now have fully functioning park heating from the programme function or the remote.
So for reference, the black wire is positive to the FBH coolant pump, negative is mustard yellow. |
