Home > In Car Electronics (L322) > V32 firmware RR splash screen
Swipe
United Kingdom 2004 Range Rover Autobiography Td6 Java Black
Guys got myself a mk4 dvd based sat nav but it has the bmw splash screen.
Been trying to download the v32 firmware and nav tweak but my pc is having none of it. Does anybody have a copy of the firmware with the Range Rover splash screen that I could have? 2004 Autobiography TD6 Java Black
Post #537973 20th Dec 2019 11:24am
Bushy30
United Kingdom 2011 Range Rover Vogue SE TDV8 Galway Green
make sure you burn the disc at the slowest speed your cd drive can do, if you don’t the disc will not work.
flashing the nav unit
1 turn the ignition switch to position 1.
2 allow the navigation system to boot up into normal operating mode.
3 leaving the system on (never turn the power off during these steps!), eject the navigation dvd from your drive unit.
4 insert the firmware disk into your nav unit.
5 watch your nav screen and be patient. once it detects the firmware update disc the screen will go blank.
6 a few moments later, the screen will turn back on. it should take around 6 minutes to perform the upgrade. when finished it will eject the cd automatically.
7 the system will restart back into its normal operating mode, reinsert your nav disc and test.
i have the files, but they are large -- not sure how to get them to you really ! Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
2004 FFRR Vogue 4.4 V8 with LPG
1997 P38 4.0 SE with LPG
1997 P38 4.6 Vogue with LPG
Post #537977 20th Dec 2019 11:40am
Swipe
Thanks bushy would you be able to put it on a disc for me and post it as my pc is playing up.
I’ll send you some money if you’d burn a disc and post it. 2004 Autobiography TD6 Java Black
Post #537981 20th Dec 2019 12:14pm
p38arover
Australia
I could put them up on Dropbox if needs be. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #537987 20th Dec 2019 12:43pm
Swipe
If you could that would be great 👍🏾 2004 Autobiography TD6 Java Black
Post #537990 20th Dec 2019 12:53pm
Swipe
That would be great if you could 2004 Autobiography TD6 Java Black
Post #537992 20th Dec 2019 1:15pm
Bushy30
Hmmmm I don't have access to a disc burner easily -- perhaps dropbox would be best from p38srover Current: 2011 FFRR Vogue SE 4.4 TDV8
Previous: -
Post #537993 20th Dec 2019 1:21pm
p38arover
Australia
PM sent Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #538070 21st Dec 2019 1:20am
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
I see my firmware is being shared about still Laughing
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos ➞ YouTube.com/RangeRoverOwner
Post #543363 7th Feb 2020 10:35pm
GGDR
Matt now that you've got a 2011 will you be be attempting any system break-ins / hacks / improvements?
LCD dash, sunset screen, dials or the crap nav system?
Smile
. Cheers, Greg
Post #543365 7th Feb 2020 10:43pm
mattstevenson2005
I’m not sure I could improve on the Ultimate Edition Laughing Current
Post #543375 7th Feb 2020 11:47pm
GGDR
Sure but needs decent satnav befitting such fine vehicle, no? Razz
. Cheers, Greg
Post #543376 7th Feb 2020 11:53pm
mattstevenson2005
It needs to stay 100% original to maintain and increase its value. But to be honest I don’t find the sat Nav too bad, never got me into trouble. Shame they stopped the updates for it in 2014 but other than that it’s a decent system. Current
Post #543380 8th Feb 2020 12:35am
p38arover
Australia
Matt
I hope that's OK, Matt Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #543385 8th Feb 2020 6:14am
JNC
United Kingdom 2011 Range Rover Vogue SE TDV8 Nara Bronze
Could you PM me a link or copy of file?
I've tried to change image myself but spent far too long even trying to get navtweak to work.
Post #545502 28th Feb 2020 10:21pm
