Home > Technical (L405) > Range Rover reversing lights
Nickfel
Hi,
Has anyone upgraded these or even aware if possible? Lights are terrible when reversing.
Nick
Post #537465 15th Dec 2019 7:42am
Mr Tee
Think they are marginally better than the 322, just mount a rear facing cibie Oscar , job done Thumbs Up
Post #537466 15th Dec 2019 7:45am
L322 or L405? ... - .- -.
Post #537468 15th Dec 2019 8:09am
Nickfel
405 thanks
Post #537486 15th Dec 2019 10:28am
the L405 reverse lights are much brighter than the L322 ones.
you have to remember that they are not specifically for illumination but they are for grabbing the attention of other road users and pedestrians that you are moving backwards..
saying that, the additional use of the brakes kinda help seeing whats behind you.. ... - .- -.
Post #537491 15th Dec 2019 10:48am
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
Ahh, the good old Cibie Oscar.....legendary !
Post #537553 15th Dec 2019 6:25pm
roberlar
I very much doubt these would fit the 405 but for anyone here with a more run of the mill vehicle these look fairly bright
https://www.newerby.co.uk/products/led-car...2729506901
Post #537652 16th Dec 2019 3:27pm
they wont Rob..the L405 rear lights are all led... ... - .- -.
Post #537658 16th Dec 2019 4:28pm
roberlar
I did wonder if there might be a single cluster LED bulb behind the lens so thanks for clarifying that Stan
Post #537684 16th Dec 2019 7:34pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
The reversing lights on the ‘405 are the single, stand out, worst thing about the car. They are okay to signal that you’re reversing to other road users, but utterly hopeless to reverse on a narrow rural country lane There’s no practical way of upgrading the glow worms in the rear light clusters, so it’s auxiliary lighting only.
A friend and I are trying to work out an auxiliary lighting solution, taking power from the reversing light cable leading to the towing socket.
Post #537690 16th Dec 2019 9:38pm
Brian Considine
If you take power from the trailer socket the car may "think" you have a trailer attached ?
Try using a relay connected to the reverse lights & pick up a live feed from the rear fusebox. 2003 Range Rover Vogue TD6
Post #537694 16th Dec 2019 11:48pm
ebajema
I have ordered a set of LED lights/reflectors that replace the original (passive) reflectors of the L322. The plan is to wire those into the reversing lights (the white LEDs). I'm sure the same can work for the L405 ? MY 2010 5.0 SC Galway green and sand interior!!
Post #537698 17th Dec 2019 6:32am
