Home > Maintenance & Mods (L322) > 2004 4.4 v8 petrol gearbox woes |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 901 |
Change the oil cooler, filter and oil in the 1st instance |
2nd Dec 2019 10:13pm |
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2215 |
does it shudder in manual mode? mine always was a bit lurch between gears as it aged (185k) but silky smooth in manual never fixed it just used it at that age Current stable:
5th Dec 2019 2:44pm |
Myblackt5 Member Since: 27 Aug 2018 Location: Cornwall Posts: 12 |
I've not tried it in Manual mode since I noticed the shudder. I might give it a go.
5th Dec 2019 2:46pm |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1254 |
Suggest a PM to RRPhil |
5th Dec 2019 4:27pm |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 969 |
If the torque converter lock-up clutch is the culprit, then it will sound a bit like driving over a cattle grid during the vibration. If you look closely, you should also see the rev. counter needle wavering a couple of hundred rpm in sympathy with the noise.
5th Dec 2019 5:57pm |
