Home > Technical (L322) > Possible progress with FBH after AGM battery install. |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Where are you getting fault codes from? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
9th Dec 2019 8:54pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8644 |
My FBH was playing up the other day, but I’m pretty sure it’s due to low battery.
9th Dec 2019 9:01pm |
I’ve just fitted an AGM. This one is a 95amps 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
9th Dec 2019 9:10pm |
Interesting, LR one?
9th Dec 2019 9:27pm |
Henda Member Since: 02 Aug 2018 Location: Gateshead Posts: 282 |
Off my bt idd tool best bit of kit you can get |
9th Dec 2019 11:47pm |
TJH1985 Member Since: 11 Feb 2015 Location: Nottingham Posts: 664 |
Did you rule out the FBH water pump in the end Andy? Sold - Bell a 2015 MY16 Loire Blue Autobiography 4.4 SDV8
10th Dec 2019 10:56am |
Really? I can’t find any fbh fault codes on my IID tool. Where are they located? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
10th Dec 2019 12:49pm |
No. Exide. £125 from euro car parts 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
10th Dec 2019 12:50pm |
Water pump? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
So I’ve just gone to pull Fuse 59 and it doesn’t exist on my car. It’s a spare slot by the looks of it. I assume my fuse box is no different to a 2008 car so why is it missing? What fuse do I pull to reset the FBH (apart from the one under the bonnet)
12th Dec 2019 1:35pm |
New LR battery.
15th Dec 2019 3:23pm |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4307 |
https://advancedbatterysupplies.co.uk/product/varta-g14/ Recommended AGM one. 95Ah Was the LR dearer? Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory" 2025MY Defender D350 90 in Silicon Silver on coils 1974 Series 3 Lightweight = "Millie" Many, many other Landies over the years My preferred specialist: www.glenrands.co.uk -------------------------------------------------- |
15th Dec 2019 4:03pm |
That is probably the same battery as the LR one which came out of mine, which was a Varys 95/850 in 019.
15th Dec 2019 4:14pm |
I just tried something which I noticed made some difference.
I bought this one for £125 from Euro Car Parts: https://www.tayna.co.uk/car-batteries/exid...gKFGvD_BwE 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded |
15th Dec 2019 4:20pm |
