Home > Technical (L405) > Alarm Going off - Won’t Start!
PLOG
United Kingdom 2019 Range Rover SVAutobiography 5.0 SC V8 Firenze Red
Hi, I’m in need of some help (and some ear plugs).
Car was fine when I got in from work this morning, locked it and went to bed. Just been woken up to the alarm going off and the Mrs panicking because it would not stop.
Neither key fob will disable the alarm/unlock the car (or start it) and the alarm won’t stop going off until we close the doors and leave it alone. The doors are still opening using keyless entry though, albeit intermittently.
Boot will not open. Doors are hit and miss. Smart keys both not recognised. At a loss, to be honest.
Had no recent battery issues with either the car or the fobs.
Has anyone else had this happen? Any info/opinions appreciated.
Thanks
Post #535619 27th Nov 2019 1:39pm
check that battery. ... - .- -.
Post #535620 27th Nov 2019 2:20pm
PLOG
Which battery? Main or auxiliary? Car doesn’t seem short of power. Not flashing up with low battery, alarm and horn sounding non-stop...
Also, I can’t open the boot... Is there a way to manually open it?
Cheers
Post #535622 27th Nov 2019 2:28pm
PLOG
Also, it had a new battery fitted a year ago by the supplying garage - I assume the main one.
Post #535623 27th Nov 2019 2:29pm
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
I have the same MY car (an AB) and replaced the main battery a short while ago but not the aux. I'm not sure the aux battery is monitored and despite research haven't found the answer. Likewise can't find much info on what the aux battery actually powers, but if it's in poor condition I'd guess it's quite likely the electrics would start playing up so I'd check the condition of that one.
Post #535642 27th Nov 2019 4:10pm
PLOG
Thanks, Roberlar. Don’t suppose you know how to open the boot manually?
Post #535659 27th Nov 2019 6:03pm
if the dors are unlocked then so should be the tailgate..press the button and manually pull up the tailgate, do the same with the lower section.... ... - .- -.
Post #535665 27th Nov 2019 6:29pm
Can you get hold of a jump pack? Or a charger? Simply connect it to the post under the bonnet and check weather its a battery low issue? Thumbs Up
Post #535673 27th Nov 2019 8:02pm
roberlar
Hadn't thought of that one, I have a Nocco Genious 150 lithium jump pack which is a very small and lightweight US product. It fits in your glovebox and defies belief. Has a useful voltage indicator as well, although i'm not sure how it would differentiate between the voltage of two different batteries off the L405 posts. That said, it's been a godsend for me with agricultural machinery such as tractors, telehandlers and so on up to around 5 litres, and I have no doubt it could handle larger engines.
Post #535679 27th Nov 2019 8:50pm
PLOG
Thanks, Stan, but the boot wouldn’t open even with a door open. I thought maybe there’d be a keyhole behind the number plate like on the Jags? Didn’t want to pull it off for no reason though...
Thanks for all the other input, but after speaking with two specialists, both said all things point to the KVM, which is apparently fairly common. So I’ll have to get it recovered to them.
Post #535700 28th Nov 2019 1:11am
rjff
Plog
Probably way out of line, but could it be the same?
The L322 has a small rectanglular black bit on the inside of the upper tailgate (offside, on the trim below the galss). Pull that gently and it opens the top. Then two latches on either side of the lower gate, reached by wiggling a finger or something to the latches on the lower gate.
You'll have to lower the rear seats and remove any load space cover. Cheers
Richard
Gap IIDBT
Post #535739 28th Nov 2019 3:50pm
PLOG
Thanks for the tip, rjff.
I’ll have a look. Unfortunately the rear seats lower electronically and the buttons are accessed from the boot! I’m sure there’ll be a way around it...
Post #535741 28th Nov 2019 3:55pm
rjff
Oh b*****r. sorry Plog. Did say I may be out of line. Hope you can get the load space cover out. ATB with it Cheers
Richard
Gap IIDBT
Post #535749 28th Nov 2019 4:37pm
PLOG
Thank you rjff, appreciate it.
Post #535750 28th Nov 2019 4:44pm
roberlar
Unbelievably, and coincidentally, went to fire mine up after being sat four days and neither keyless entry or either of the two remotes worked to unlock, or indeed operate anything. Tried the tailgate (manual button) which opened and subsequently everything went back to normal. Relieved but at the same time dissapointed Shocked
Post #535786 28th Nov 2019 10:08pm
