Home > Technical (L405) > Alarm Going off - Won’t Start! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35476 |
check that battery. ... - .- -.
27th Nov 2019 1:20pm |
PLOG Member Since: 19 Nov 2018 Location: Teesside Posts: 25 |
Which battery? Main or auxiliary? Car doesn’t seem short of power. Not flashing up with low battery, alarm and horn sounding non-stop...
27th Nov 2019 1:28pm |
Also, it had a new battery fitted a year ago by the supplying garage - I assume the main one. |
27th Nov 2019 1:29pm |
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 |
I have the same MY car (an AB) and replaced the main battery a short while ago but not the aux. I'm not sure the aux battery is monitored and despite research haven't found the answer. Likewise can't find much info on what the aux battery actually powers, but if it's in poor condition I'd guess it's quite likely the electrics would start playing up so I'd check the condition of that one. |
27th Nov 2019 3:10pm |
Thanks, Roberlar. Don’t suppose you know how to open the boot manually? |
27th Nov 2019 5:03pm |
if the dors are unlocked then so should be the tailgate..press the button and manually pull up the tailgate, do the same with the lower section.... ... - .- -.
27th Nov 2019 5:29pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 |
Can you get hold of a jump pack? Or a charger? Simply connect it to the post under the bonnet and check weather its a battery low issue? |
27th Nov 2019 7:02pm |
Hadn't thought of that one, I have a Nocco Genious 150 lithium jump pack which is a very small and lightweight US product. It fits in your glovebox and defies belief. Has a useful voltage indicator as well, although i'm not sure how it would differentiate between the voltage of two different batteries off the L405 posts. That said, it's been a godsend for me with agricultural machinery such as tractors, telehandlers and so on up to around 5 litres, and I have no doubt it could handle larger engines. |
27th Nov 2019 7:50pm |
Thanks, Stan, but the boot wouldn’t open even with a door open. I thought maybe there’d be a keyhole behind the number plate like on the Jags? Didn’t want to pull it off for no reason though...
28th Nov 2019 12:11am |
rjff Member Since: 28 Oct 2017 Location: Cambridgeshire Posts: 1196 |
Plog
28th Nov 2019 2:50pm |
Thanks for the tip, rjff.
28th Nov 2019 2:55pm |
Oh b*****r. sorry Plog. Did say I may be out of line. Hope you can get the load space cover out. ATB with it Cheers
28th Nov 2019 3:37pm |
Thank you rjff, appreciate it. |
28th Nov 2019 3:44pm |
Unbelievably, and coincidentally, went to fire mine up after being sat four days and neither keyless entry or either of the two remotes worked to unlock, or indeed operate anything. Tried the tailgate (manual button) which opened and subsequently everything went back to normal. Relieved but at the same time dissapointed |
28th Nov 2019 9:08pm |
