![]() | Home > General > 3.6 TDV8 far superior to 4.4TDV8 |
jackie-o Member Since: 15 Jun 2018 Location: Sweden Posts: 226 ![]() ![]() |
Sorry for the fake news headline, just wanted to grab some attention...
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7915 ![]() ![]() ![]() |
Well, I paid more money to skip the 3.6 altogether and went from TD6 to 4.4 TDV8.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
There are potential faults with any - same with the L405 engines - it's a roll of the dice IMHO
kooky_guy Member Since: 25 Nov 2011 Location: Sandhurst, Berkshire Posts: 386 ![]() ![]() ![]() |
No idea how true it is, but I've seen mentioned in a couple of places that the 4.4 was introduced specifically to overcome the inherent design issues with the 3.6 and it's turbos. 2010 4.4 TDV8 Vogue SE |
DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4334 ![]() ![]() ![]() |
I've just had the secondary turbo replaced on my 4.4 TDV8 at 95K.....also had oil pump leaks fixed, oil cooler in "V" leaks fixed and a few other bits....see here for full list of stuff done since Sept 2018:
So basically the main point is that the 3.6 is death by decapitation and the 4.4. is death by a thousand cuts with the opportunity to escape? RR Vogue 4.4 TDV8 - 11
There have been catastrophic 4.4 failures too.
So my initial point stands? RR Vogue 4.4 TDV8 - 11
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3552 ![]() ![]() ![]() |
Dunno, everyone here who has driven both say the 4.4 is streets ahead.
Depends what your initial point is |
Brian Considine Member Since: 15 Apr 2019 Location: Garlinge Posts: 428 ![]() ![]() |
I've known a few people that have had RRS's & they do not look after them, maintaining or driving wise. 2003 Range Rover Vogue TD6 |
The initial point doesn’t stand, the 3.6 could let go at any time without warning and then you will be left with a very expensive paper weight.
hahahaha, Alistair i´m not sure what it was |
I’d agree with that.
