Home > General > Hi all newbie here |
oodathort Member Since: 01 Nov 2010 Location: just there Posts: 191 |
Hi get your battery checked |
29th Mar 2011 2:51pm |
baz_rsp Member Since: 29 Mar 2011 Location: Aberdeen Posts: 22 |
Battery?? The jeep recived a new battery at the last service about 2k ago.
29th Mar 2011 2:59pm |
and don't call it a "Jeep" or you will get jumped on.....
29th Mar 2011 3:00pm |
This may sound overly critical, especially for your first post, but PLEASE do not call it a Jeep. This will not do yourself any favours. It is not a Jeep, a Jeep is a model of car quite seperate to Range Rover.
29th Mar 2011 3:01pm |
And for balance, check out this thread RE your check engine light:
29th Mar 2011 3:02pm |
Sorry didn't mean to offend, From aberdeen we speak funny up here, ken fit like! |
29th Mar 2011 3:04pm |
29th Mar 2011 3:08pm |
Furryboots then Baz ............... Furryboots is ris and Furryboots is rat ....... Used to work for S.Bruce Blackdog Ind Estate ....... A Weegie .... ====================================
29th Mar 2011 3:11pm |
Thanks for that dan, will have to check when i get back onshore. so that should sort most my problems? sorry about all the questions normally used to smaller stuff i.e minis
29th Mar 2011 3:14pm |
if the battery is low on power when you start the car it pulls the voltage i suspect below 9v this then triggers the various ecus to go into backup mode hence the faults |
29th Mar 2011 3:16pm |
cheers for the replys, you lads are quick on here.
29th Mar 2011 3:21pm |
We all sit waiting to pounce on newbie Jeep owners that work on the rigs..... |
29th Mar 2011 3:25pm |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 |
Mick, that looks distinctly like the 2013 RRS in your signature................. you sure you copied the right pic? 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - it’s whisper quiet in EV and polluter modes |
29th Mar 2011 3:26pm |
You must be as busy as I am then |
29th Mar 2011 3:32pm |
