Home > General > Hi all newbie here
Just a random Image Tim........ Thumbs Up
@ Baz the company not there any longer took over by ARR CRAIBS Thumbs Up ====================================
Post #57326 29th Mar 2011 4:34pm
baz_rsp
Scotland 2004 Range Rover Vogue 4.4 V8 Java Black
Ah they own everything now, not giving the small companys a chance..
Post #57327 29th Mar 2011 4:39pm
daveo
hi, welcome..i get around 220 out of 60 pounds worth of petrol on the run with a little town driving,
check your pcv system,the two hoses at the back of the engine as this can bring you engine light on and give you bad mpg...check dan-uk post as he dont a how to do it post that was very good... V8 facelift Range Rover Autobiography 22" wheels.
Post #57328 29th Mar 2011 4:51pm
baz_rsp
Thanks Daveo, so in rights i should see about 400+ out a full tank of fuel??
My mate who was on here rory_mcwilliam was saying he used to see 350ish out his v8 but he drove his quite hard, will be a bonus if i was to get that from changing the PVC hoses.
Post #57333 29th Mar 2011 5:15pm
dan_uk_1984
PCV's is a good start, there are 2 hoses on top and 2 beneath that when fail allow unmetered air to enter the engine.
You really shouldn't be driving the car whilst the MIL is on unless you are confident that the cause is benign.
The manual is quite explicit with its warning:
The light illuminates as a bulb and
system check when the starter
switch is turned on, and
extinguishes as soon as the engine is started.
Illumination at any other time indicates an
engine fault - if the light illuminates or flashes
while driving, avoid high speeds and seek
qualified assistance urgently.
When an engine replacement will run to the tune of around 5K it really isn't worth driving it into the ground for the want of a fault code being read.
That being said - it is still more likely to be a vacuum leak from a gaping PCV hose.
Post #57354 29th Mar 2011 6:10pm
