Home > For Sale & Wanted > [For Sale] Full L322 Tow Pack
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
Full kit to attach to factory mounting points and plug and play, inc ball with key
£395 plus post
[/img] One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #533801 11th Nov 2019 12:17pm
from what year car ? .
Post #533804 11th Nov 2019 1:12pm
JohnnyDangerous
2003 but fits any L322 One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #533844 11th Nov 2019 9:57pm
kooky_guy
United Kingdom 2010 Range Rover Vogue SE TDV8 Stornoway Grey
I thought the exhaust hangers were different on late cars?
Exactly what I'm looking for, but I don't want to have to faff about cutting and welding. 2010 4.4 TDV8 Vogue SE
Post #534041 13th Nov 2019 9:45am
Harmitans
United Kingdom 2008 Range Rover Vogue SE TDV8 Santorini Black
They are indeed different. On the later cars, there is a small vertical piece near the front mounting hole to which the exhaust is bolted to (shown in the attached picture). You could make something to do the job easily enough with a piece of steel with a 90 degree bend with a couple of drilled holes if you wanted to use the early towbar on a later car.
Post #534089 13th Nov 2019 3:33pm
Harmitans
Post #534090 13th Nov 2019 3:33pm
JohnnyDangerous
You would think that a bent tab would just be bolted on using the mounting bolt but if anyone has a pic of what the tad does Ill weld a pair on that way it fits any year, does it have 1 or 2 holes etc or captive nuts etc One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #534132 13th Nov 2019 6:57pm
Harmitans
Just one hole, no captive nuts.
Post #534173 13th Nov 2019 10:13pm
JohnnyDangerous
Maybe better if I just weld a tab on and leave the hole so it can be marked or do you think just drill 2 holes so the exhaust can be mounted in the best placed ones? One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #534200 14th Nov 2019 10:09am
Harmitans
https://www.ebay.co.uk/itm/Range-Rover-L32...ition=3000
Take a look at these, not the clearest image but best I could find.
Post #534204 14th Nov 2019 10:25am
Gsxr1250dave
I dont need one but I'm tempted but it's a bit rich for me
Post #534292 14th Nov 2019 10:53pm
JohnnyDangerous
Had this sold to GSXR Dave but due to circs beyond his control he had to pull out.
Just need this gone now, 2 keys and all wires/relays etc plug and play, I can weld the tabs on for later models no problem if required
Black Friday special
£250 One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #536061 1st Dec 2019 11:04am
Gsxr1250dave
Yes very sorry again john bit of a stressful time at the moment and on top of all that I come out from my MRI spinal scan to find some dickhead has reversed into my off side rear light and smashed it.
Iv sent a message to someone on here selling one.
Post #536093 1st Dec 2019 3:43pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
sorry to put another spanner in the works I don't think your electrics will work on the 2010/12 l322 as it has a single plug and no coding required?
Post #536098 1st Dec 2019 6:12pm
JohnnyDangerous
Good point I only know it goes on the first facelift ones from 2006-10 but the body and all metal parts fit, ebay want £250 just for ball and holder so still a cheaper way around. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #536128 2nd Dec 2019 10:02am
