Home > Technical (L322) > Suddenly car would stop shifting up from first gear.
FEM888
United Kingdom 2004 Range Rover HSE Td6 Java Black
Hi Everyone,
L322 TD6 5L40E 2004
Driving home this evening, come off the Motorway after 20 miles stopped at red lights, car behaved up to the red light, then had to travel last 1/2 mile in 1st gear as the car would not shift out of first gear when in Drive or manual override (2 or 3 or 4 can be selected on the dash when moving). Got home, reverse neutral and park still working. The transmission had logged a fault: Trans fail safe mode.
Used IIDTool to clear faults. Test drive whilst still hot, still only have 1st, reverse, neutral and park available.
Allowed car to cool overnight, fully charged battery as precaution, test drive from cold, still same fault.
Checked resistances from EAT ECU connector C1835. All within spec (allowing for slight resistance of leads from ECU to gearbox)
Shift valve solenoid A 16.7 ohm
Shift valve solenoid B 17.2 ohm
Shift valve solenoid C 16.9 ohm
TCC PWM solenoid 11.7 ohm
Pressure regulator solenoid 4.8 ohm
Input shaft speed sensor 407.0 ohm
Output shaft speed sensor 399.0 ohm
Temperature sensor 2180.0 ohm
EAT ECU Output
Solenoid A B C
D off on off
M1 off on on
M2 on on on
IID transmission live values gives realistic oil temperature, engine speed turbine speed an output shaft speed.
Any helpful suggestions gratefully appreciated.
Many thanks.
Post #533546 8th Nov 2019 5:10pm
RRPhil
Sounds like an issue with the Second Clutch.
The Second Clutch is used in 2nd, 3rd, 4th & 5th gears but not in 1st & Reverse.
Phil
Post #533678 10th Nov 2019 1:30am
FEM888
Hi Phil, thanks for the tip and pointing to where to look.
I got around to dropping the valve block and found the 1-2 shift valve stuck in the applied position.
Further striping down found the spring in the 2nd clutch accumulator broken
The resultant sharp end of the spring had been cutting into the aluminium spring seat and creating swarf which can be seem on the cotton bud.
I flushed the valve block without taking it apart and replaced the spring. All seem OK the car has been running about 1000 mile without any shifting problems.
Many thanks
Post #704379 13th Nov 2024 6:28pm
dingg1
Did it take you 5 years to get round to sorting it 😳
Post #704381 13th Nov 2024 6:38pm
hmallett
United Kingdom 2013 Range Rover Autobiography SDV8 Firenze Red
I am as intrigued about the timeline of this as I am about the technical fix!
Post #704383 13th Nov 2024 6:56pm
FEM888
Very Happy I was busy and I don't have the equipment or space to strip down an automatic gearbox. And because of the low value it wasn't worth paying £2500 for a recon box with 12 month warranty. So it was SORN and left until I had spare time.
Post #704385 13th Nov 2024 7:10pm
