Home > Technical (L322) > Car wont start. Parking light flashing red
woldsman
United Kingdom 2008 Range Rover Autobiography TDV8 Java Black
to replace the ignition switch on my 2008 tdv8 is there an easy way to get at it or is it a full lower console removal . tried the search function on the forum but can't find anything re replacing the ignition switch . I am new to the forum so maybe I am looking in the wrong place .... Thanks for any help
Post #599672 5th Jul 2021 8:27am
Sam
Mate, prepare yourself, it's a bit of a faff......
Post #599677 5th Jul 2021 8:55am
woldsman
thanks Sam , scary job then ?
Post #599680 5th Jul 2021 9:14am
Sam
Yes and no. There's not really any element of the job that's difficult, there's just a lot of it. The biggest faff is probably getting the airbag off the steering wheel! Just take your time and be methodical.
Top tip though; once you've re-assembled everything don't push the airbag pad all the way home on it's clips until you've driven it for the first time as in all likelihood the steering wheel will be slightly off center and you'll have to take it off again.
Post #599688 5th Jul 2021 9:54am
woldsman
thanks sam - very helpful . will have some nerve tablets for lunch and have a go .....
Post #599693 5th Jul 2021 10:24am
Sam
Remember to disconnect the battery!
Post #599699 5th Jul 2021 10:44am
dingg1
Before you remove the steering wheel, mark the position with a felt pen across the splines Thumbs Up
Post #599701 5th Jul 2021 10:51am
Merchy
This may help to start the job, steering wheel and air bag removal video from Powerful UK
As in above posts, not difficult, just a faff to do, if you are not used to doing anything like this use a piece of cardboard and stick fasteners into cardboard and ID each set upon removal, then you won't mix them up upon re-fitting. Ask me how I know Whistle we all make mistakes.
A car trim tool kit would help with this job. Cheap and very handy.
Post #599717 5th Jul 2021 2:22pm
Swanny66
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
Hi Sam,I have the same problem with my 2007 L322 vogue,it needs the ignition switch sorted,know dash lights,brake lights on etc,
Iam also located west Sussex,the car is stuck on my drive!
Do you know of anybody mobile who could fix this for me.
Kind regards Steve.
Post #645155 9th Oct 2022 8:09am
Swanny66
Hi all,are there any mobile mechanics local to west Sussex that could do the ignition switch on my L322?
Post #645157 9th Oct 2022 8:29am
Diff
Canada
Wondering if you got this sorted. I removed the main ground strap under right side as it was terribly corroded and when I turned the key I got red taillights and blinking front markers and numerous fault messages. They all disappeared when ground strap replaced. Just a thought as it lurks down there and I never noticed it. That assumes the car is in a corrosive environment and the strap is made up of numerous very thin copper strands which corrode easily.
Post #652863 7th Jan 2023 2:25pm
