![]() | Home > Technical (L322) > Car wont start. Parking light flashing red |
Sam Member Since: 02 Jun 2017 Location: West Sussex Posts: 89 ![]() ![]() |
Mate, prepare yourself, it's a bit of a faff......
woldsman Member Since: 03 Jul 2021 Location: east yorkshire Posts: 6 ![]() ![]() ![]() |
thanks Sam , scary job then ? |
Yes and no. There's not really any element of the job that's difficult, there's just a lot of it. The biggest faff is probably getting the airbag off the steering wheel! Just take your time and be methodical.
thanks sam - very helpful . will have some nerve tablets for lunch and have a go ..... |
Remember to disconnect the battery! |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1351 ![]() ![]() |
Before you remove the steering wheel, mark the position with a felt pen across the splines |
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1214 ![]() ![]() ![]() |
This may help to start the job, steering wheel and air bag removal video from Powerful UK
Swanny66 Member Since: 09 Oct 2022 Location: Surrey Posts: 3 ![]() ![]() ![]() |
Hi Sam,I have the same problem with my 2007 L322 vogue,it needs the ignition switch sorted,know dash lights,brake lights on etc,
Hi all,are there any mobile mechanics local to west Sussex that could do the ignition switch on my L322? |
Diff Member Since: 17 Dec 2022 Location: Grafton Posts: 3 ![]() ![]() |
Wondering if you got this sorted. I removed the main ground strap under right side as it was terribly corroded and when I turned the key I got red taillights and blinking front markers and numerous fault messages. They all disappeared when ground strap replaced. Just a thought as it lurks down there and I never noticed it. That assumes the car is in a corrosive environment and the strap is made up of numerous very thin copper strands which corrode easily. |
