Home > In Car Electronics (L322) > Rear Entertainment Remote Problem
Hallza
United Kingdom 2014 Range Rover Vogue SE SDV8 Luxor
Good evening,
Hopefully someone can help/point me in the right direction.
Currently my rear entertainment remote is non responsive and will not charge, tried another remote/battery and left it in the cradle just in case it might start charging or the fairy’s fix it but have the same issue.
Is the power feed protected by a specific fuse that’s not listed in the manual?
Checked the cradle pins with a multimeter and no voltage found hence not charging.
Has anyone else had this issue/fixed before?
RR is a 2011 autobiography TDV8.
Many thanks in advance,
Hallza.
Post #533356 6th Nov 2019 8:20pm
dazza1983
United Kingdom 2011 Range Rover Vogue 4.4 V8 Santorini Black
I’m guessing you checked the pins with the engine running ?
If your not getting any voltage then I’d say that’s your problem.
Maybe a break in a wire where the arm rest goes up and down? Regards
Daz
2011 (61plate) 4.4 tdv8
sumatra black
previous cars
e46 m3
e53 x5
Post #533357 6th Nov 2019 8:27pm
Hallza
Hi Daz
Thanks for your reply,
I’ve tried with and without the engine running although I’d expect it to only charge whilst it’s running.
Is the cable routed a specific way?
Does it connect under the folding seat or boot area?
Many thanks,
Post #533359 6th Nov 2019 8:49pm
