Home > Range Rover Classic > 1988 3.5 EFi 5 speed manual
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
I have an 'F reg' 3.5 EFi 5 speed manual which belonged to my late father who died in 2000. Kept it for sentimental reasons and it hasn't been driven since, but now considering selling. It hasn't been MOT'd since. It's covered 84,000 miles and is totally original, but has been kept outside hence most steel parts have gone a bit rusty. Has some superficial damage to the drivers side rear door and wing but ran absolutely spot on when last driven. It's a far cry from my current L405 but might be an attractive restoration project to the right person. Any thoughts on what price I should ask much appreciated
Post #532132 25th Oct 2019 6:54pm
Rosco
I'm afraid you are entering a minefield ! I have had a few classics over the years and currently looking for another one. Prices are all over the place but they are definitely continuing to rise. Your biggest issue will be the rust, has it got to the inner wings/ boot floor etc. These are the areas that are relatively expensive to do, unless you are very handy with a welder. \my advice would be do spend an hour searching all available classics within a couple of years either way to yours and basing your price on that, you have a lot of plus points, history, mileage etc. Hope that helps but probably not Rolling with laughter
Post #532134 25th Oct 2019 7:14pm
roberlar
Thanks Rosco, doesn't seem to be any significant corrosion i.e. rust holes, but surface corrosion for sure
Post #532135 25th Oct 2019 7:28pm
Vogue
FWIW, I sold my Classic 2 years ago, similar miles at 98k, FLRSH, 3.9 V8 - all bills and history - totally original but needed new inner wings and Sills - otherwise perfect, no filler and trim perfect with no cuts rips tears or fag burns, she drove like stink but needed the brakes doing - got £6.5k sold on a SORN, bought by a dealer. I would have kept her but have far too many vehicles. 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #532141 25th Oct 2019 9:16pm
gettingold
Keep it and do the work yourself or get it done overtime. You may regret it once it’s gone........
Steve.
Post #532150 26th Oct 2019 5:53am
roberlar
Thanks to all for your thoughts. Perhaps the suggestion to hang on to for now it is the wise thing to do..... and get it under cover to minimise deterioration pending restoration work
Post #532161 26th Oct 2019 10:13am
