Home > In Car Electronics (L405) > GPS Splitter
supershuttle
GPS Splitter
I've been watching with interest fitting an Android Head Unit to my old L405. I can cope with the extra mic and speaker (they can be hidden) but the GPS arial is a different matter so I was wondering if its possible to split the existing GPS cable and supply the android stuff while maintaining the normal Sat Nav. Geoff
Post #531762 22nd Oct 2019 8:38am
charlie croker mk2
I would have thought that trying to split your gps into 2 outlets is not going to work but you could try ? Maybe a bit like trying to split your TV aerial cable ie 100% into the splitter only 30% available on each leg etc . I would fit a new gps and feed it directly into the new unit .
Personally i would be making sure that whatever you do can be reversed as when you come to sell your car a new buyer or dealer is going to mark your value down because if non standard kit or even worse customisation !
Post #531769 22nd Oct 2019 11:12am
the gps antenna that comes with the android unit isnt that big and could easily be located at the bottom of the windscreen without looking out of place.. ... - .- -.
Post #531783 22nd Oct 2019 1:09pm
andygts
Over the years I've had 2 different sony/tomtom double din headunits in 2 different cars and on both I put the GPS antenna under the dash and never had a problem Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #531784 22nd Oct 2019 1:20pm
Mariana Black
England 2014 Range Rover Autobiography TDV6 Mariana Black
Hi Geoff
Have you bought one of the Android head units?
I have looked at various youtube videos and I think but would like to be corrected that the only thing you miss is the dual screen. Everything else is the same with extra.
The GPS module should be able to be fitted under the dash but near the top but away from speakers I think.
Any comments would be appreciated
3.0 14M5 Autobiography
Post #531834 22nd Oct 2019 7:22pm
supershuttle
No. I haven't bought one yet, loss of dual screen functionality is no problem to me, I only ever show it off to people as its cool but its never been used to watch TV or a Video by a passenger. However, I'm not actually sure this unit is worth the bother for what I do, which is play a bit of Spotify, a lot of radio2 and I just updated the SatNav, sure its a bit slow but then so am I Rolling with laughter .The main issue I have is that people text or WhatsApp me while I'm driving and as far as I can see this unit does nothing to help. My daughters Ford actually reads out text messages maybe even WhatsApp - I don't know - but as far as I can see this unit doesn't do either. I actually do use Waze and Speed Camera alerts from my mobile occasionally if I need to.
But it looks cool and that might carry the day! Geoff
Post #531848 22nd Oct 2019 8:52pm
having waze on the FF screen would be nice... ... - .- -.
Post #531849 22nd Oct 2019 8:55pm
supershuttle
Also cool !! Geoff
Post #531851 22nd Oct 2019 8:57pm
Mariana Black
Geoff
I do think there is another add on you need to buy to connect into the usb flying lead. I thinks it’s around £40 and it a dongle that connects your iPhone via Appleplay but need to do more reading. It’s funny how everyone goes on about the sat nag 🤔 I upgraded mine. Yes it took 3 hours but did improve the locations but not the speed.
I would like to be able to play my iPhone ie mirror it as I have music and films I wish to watch. Text reading would be useful.
Post #531852 22nd Oct 2019 9:08pm
BigladUK
United Kingdom 2014 Range Rover Autobiography SDV8 Causeway Grey
If you are going to use Apple Carplay with Waze or Google Maps then a GPS anntenna isn't required as the GPS comes from your phone.
The speaker is only required if you are running SatNav via the Android system ( or Apple Car Play ) but don't have the Car's Audio system set to Aux in so listening to the Radio, the speaker is only really for Audio prompts for Sat nav ( if you use them ) whilst not listening to Aux In.
Make sense ?
Si
Post #531899 23rd Oct 2019 9:42am
supershuttle
I know this is an old thread but my Sat Nav says no signal from the aerial. I bought a cheapo aerial on eBay I assume there is a sat nav lurking somewhere in my car that I can connect it to - where? The reason I am doing it this way is that if I try to remove the trim, drop the headlining and replace the original roof aerial (I suspect water ingress) I’ll break something - I always do. Embarassed Geoff
Post #598824 26th Jun 2021 7:00am
CongoBoy
South Africa 2005 Range Rover Vogue SE 4.2 SC V8 Java Black
There's a guide in the Wiki on the Forum.
It's for the L332 though but probably similar??
Also this from Powerful UK
https://www.youtube.com/embed/x4RtpLUUEmA?rel=0 2005 FFRR SC Java Black with Overfinch Exhaust (UK)
2008 D3 HSE Stornoway Grey (UK)
2008 D3 HSE Izmir Blue (ZA/Zimbabwe)
1995 D1 300 Tdi (Zimbabwe)
Post #598828 26th Jun 2021 7:37am
Go in through the boot Geoff... Ive replaced a couple now that have been knocked off/smashed... 2 10mm nuts, easy peasy Thumbs Up
Post #598900 26th Jun 2021 10:48pm
supershuttle
I started this but I don't think its so easy on an l405 as it is on an l322 so I put everything back together and will have another go, another day. In the meantime Waze on my mobile will have to do, well actually apart from the screen size its better that the standard fitment. I also have to program in drives but thats no problem as I am either local (no need for any nav) or travelling a distance in which case Waze is better. Geoff
Post #605464 3rd Sep 2021 7:09am
spbee
https://www.ebay.co.uk/itm/GPS-Splitter-Ca...gJuevD_BwE
Post #605489 3rd Sep 2021 12:33pm
