![]() | Home > Maintenance & Mods (L322) > Starter Motor Click |
brian1951 Member Since: 07 Nov 2015 Location: Salop Posts: 275 ![]() ![]() |
Identical problem last year on mine, bought a starter and battery, only fitted the battery and its been fine ever since, still got the new starter and still waiting for it to fail. |
V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 374 ![]() ![]() ![]() |
Battery was new in January so do not think that is issue but will check voltage 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Dirty contacts in the starter then, there is a thread on the starters somewhere, i was lucky |
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1209 ![]() ![]() ![]() |
I replaced the battery and replaced the stater ( Opie Oils ) no problems since |
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
If & when my goes, I would favour taking the starter out & see if someone can do an old fashioned 'refurb'. I'm not a fan of 'reconditioned' units from your local motor factors.
GGDR Member Since: 26 Nov 2016 Location: London Posts: 3551 ![]() ![]() ![]() |
IIRC Mike (Baltic Blue) looked into refurb with a similar type of guy.
I thought of the refurb way then phoned around most places wanted to sell with a return of the old unit which happened to be more money than Opie Oils and Its the same make model as Dan Duckworths also did not have to send the old unit back Just my take on what I found out.
TomCobbly Member Since: 29 Jun 2016 Location: Guildford Posts: 122 ![]() ![]() ![]() |
As far as refurb goes the parts that get burned and blackened are the high current contacts in the solenoid. Unfortunately you can't buy replacements although it is possible to clean them up but I doubt that would last very long.
Thinking about it does the L405 SDi V8 suffer from the same problem and if not what is the difference |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3789 ![]() ![]() ![]() |
https://www.fullfatrr.com/forum/topic50836.html
https://www.fullfatrr.com/forum/topic51227.html
Is anyone running a refurb'ed starter?
