Home > Maintenance & Mods (L322) > Starter Motor Click
V8 Bob
United Kingdom 2012 Range Rover Westminster TDV8 Ipanema Sand
Starter Motor Click
So it has started to make the dreaded click when trying to start....immediately after a 500 mile round trip partly in torrential rain. Have read the wiper trick but at the moment is starting on second attempt of the button.
Two questions for those in the know:
How long o you expect it to keep starting albeit not at the first go?
Would you replace with an original LR starter or a Bitoart one?
Cheers 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
200 TDi discovery bobtail gone
RR classic v8 bobtail gone
300 tdi Discovery 3 dr gone
Post #531712 21st Oct 2019 7:07pm
brian1951
2012 Range Rover Westminster 4.4 V8 Orkney Grey
Identical problem last year on mine, bought a starter and battery, only fitted the battery and its been fine ever since, still got the new starter and still waiting for it to fail.
Post #531717 21st Oct 2019 7:29pm
V8 Bob
Battery was new in January so do not think that is issue but will check voltage 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
Post #531724 21st Oct 2019 8:07pm
brian1951
Dirty contacts in the starter then, there is a thread on the starters somewhere, i was lucky Bow down
Post #531726 21st Oct 2019 8:14pm
Tinman
United Kingdom 2017 Range Rover Autobiography SDV8 Silicon Silver
I replaced the battery and replaced the stater ( Opie Oils ) no problems since
Post #531734 21st Oct 2019 9:24pm
Fox889
If & when my goes, I would favour taking the starter out & see if someone can do an old fashioned 'refurb'. I'm not a fan of 'reconditioned' units from your local motor factors.
Luckily, in deepest rural Suffolk, we have a time warp electro workshop with steam powered [not really] lathes & oily covered machinery where the guy refurbs back to better than original. Unfortunately, these kind of places are getting harder to find. 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #531747 22nd Oct 2019 5:40am
GGDR
IIRC Mike (Baltic Blue) looked into refurb with a similar type of guy.
Answer was no after he opened it up.
Can't remember why.
Have a search, or Mike if you're reading was that right?
. Cheers, Greg
Post #531750 22nd Oct 2019 6:30am
Tinman
I thought of the refurb way then phoned around most places wanted to sell with a return of the old unit which happened to be more money than Opie Oils and Its the same make model as Dan Duckworths also did not have to send the old unit back Just my take on what I found out.
Your looking for a Denso unit
Post #531752 22nd Oct 2019 6:47am
TomCobbly
As far as refurb goes the parts that get burned and blackened are the high current contacts in the solenoid. Unfortunately you can't buy replacements although it is possible to clean them up but I doubt that would last very long.
I eventually replaced my starter motor and it was fine for a while but is beginning to be unreliable again.
Other things to try are to take the load off the steering lock by turning the steering wheel slightly.
I find locking the doors seems to help for some reason and also the windscreen wiper trick if all else fails.
I read somewhere that the click could be the sound of the turbo actuator rather than the solenoid but I don't know how that helps. Confused 2011 4.4 TDV8 Vogue SE
1993 Discovery 1 3.5 V8i
Post #531754 22nd Oct 2019 7:08am
TomCobbly
Thinking about it does the L405 SDi V8 suffer from the same problem and if not what is the difference Question 2011 4.4 TDV8 Vogue SE
Post #531755 22nd Oct 2019 7:13am
Baltic Blue
https://www.fullfatrr.com/forum/topic50836.html
Replacement solenoid contacts are not available
The only way to do a refurb is to strip and rebuild when the contacts have been cleaned.
Mike.
 G reg 2.5VM Vogue Portofino red 1991- 1999
Post #531757 22nd Oct 2019 7:39am
Baltic Blue
https://www.fullfatrr.com/forum/topic51227.html
Link to the other relevant post that I couldn’t find earlier.
Mike G reg 2.5VM Vogue Portofino red 1991- 1999
Post #531922 23rd Oct 2019 3:40pm
GGDR
Is anyone running a refurb'ed starter?
. Cheers, Greg
Post #532152 26th Oct 2019 7:08am
