![]() | Home > In Car Electronics (L405) > Best audio source for sound quality? |
dexion7 Member Since: 06 Jun 2013 Location: Tynemouth Posts: 291 ![]() ![]() |
CD will be best.
DrF Member Since: 30 Jun 2014 Location: South East Posts: 1465 ![]() ![]() ![]() |
CD definitely |
charlie croker mk2 Member Since: 21 Jun 2017 Location: Yorkshire Posts: 174 ![]() ![]() |
In order of highest Q / bit rate / less compression
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
can't speak for the other streaming services, but if you only have the basic Amazon Music, their streaming sample rate is quite low, hence they off their premium"HD music" (at a cost of course) |
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
I plan to use my iphone via the USB input using a quality cable form AudioQuest. My phone has a mixture of MP3 and apple lossless formatted music.
gilesharrison Member Since: 04 Aug 2018 Location: Cumbria Posts: 163 ![]() ![]() ![]() |
I'm no phone expert, but how can Ann iPhone NOT have an onboard DAC? It is able to play audio through its own speaker. |
Yes all devices that convert digital audio to analog Audio must have a DAC that's what DAC stands for, however there are many different types of chipsets and a high quality source connected via the jack as opposed to Bluetooth as Buz is doing will be the most pure available for that type of device . |
notty Member Since: 05 Jun 2017 Location: NE Hants Posts: 35 ![]() ![]() ![]() |
Pragmatically, lossless music (AAC?) at a high bit rate (up to 320kbps) via something like Tidal and using the USB connection should be best.
Ginja Member Since: 17 Mar 2016 Location: England Posts: 26 ![]() ![]() |
I've been using my iphone via usb to access my iTunes library which has a mix of apple lossless and mp3 files. I also have amazon music hd which also plays through the usb. Recently though I've lost the ability to access my iTunes library through the screen, or indeed skip files through the steering wheel controls. I've tried a reset, restart and repairing but I only ever get a temporary resolution, music plays but I can only control it through the phone itself. My wife also has the same problem in her evoque. Has anyone else had this and is there a solution? We both have iphone 6s phones. |
Get a blackberry |
awclymm Member Since: 09 Jun 2012 Location: Cheshire, UK Posts: 135 ![]() ![]() ![]() |
As above - Tidal - fabulous! 2017 4.4 SDV8 Autobiography |
Red Merle Member Since: 19 Sep 2016 Location: Cornwall Posts: 2158 ![]() ![]() ![]() |
Gramophone |
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 ![]() ![]() ![]() |
In my humble opinion, (and i'm very critical on sound) it very much boils down to the recording quality at source. I have tracks on ipod which sound far better than CD and vice versa. Furthermore, bass and treble often need adjusting accordingly if you're that way inclined. |
ilard Member Since: 21 Oct 2012 Location: London Posts: 713 ![]() ![]() |
That's a very interesting observation, roberlar.
