Home > In Car Electronics (L405) > Best audio source for sound quality?
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
My SDV8 AB has the Meridian Reference system, 1700w and 29 speakers, and I'm keen to understand which is the best input to use so that I get the best sound production from the music on my iPhone.
I'm currently streaming music from iTunes and Amazon Prime via Bluetooth and occasionally using CDs.
The choices as I see it are as follows :
Bluetooth
Aux-in
USB
CD 2019 L405 SDV8 Autobiography
2023 Defender P400e HSE X-dynamic - gone
2020 Defender P300 SE - gone
2019 Jaguar F-Pace SVR - gone
2013 SDV8 Autobiography - gone
2011 L322 TDV8 Vogue SE - gone
2006 L322 3.6 Vogue Se - gone
1999 P38 4.0 se - gone
199? Classic 3.5 - gone
Post #531353 18th Oct 2019 5:49pm
dexion7
2010 Range Rover Vogue SE TDV8 Alaska White
CD will be best.
most sources apart from CD have compression or other factors of various sorts which have a negative impact upon quality
Post #531360 18th Oct 2019 8:43pm
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
CD definitely Thumbs Up
Post #531365 18th Oct 2019 9:14pm
charlie croker mk2
In order of highest Q / bit rate / less compression
CD
FM radio
High bit rate mp3
Dab radio from primary sources
Low bit rate MP3
Dab radio from secondary sources
If you have the surround / meridian effect on ? this will change the pure sound into ( still good ) but less pure due to the phase difference built it to the effect .
An Iphone via bluetooth is unlikely to give the best quality although it may flatter to deceive , it will depend of the source you originally got the music from .
Post #531425 19th Oct 2019 11:46am
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
can't speak for the other streaming services, but if you only have the basic Amazon Music, their streaming sample rate is quite low, hence they off their premium"HD music" (at a cost of course)
Post #531623 21st Oct 2019 11:14am
Buz1500
I plan to use my iphone via the USB input using a quality cable form AudioQuest. My phone has a mixture of MP3 and apple lossless formatted music.
My phone is an iPhone 7 Plus and as such it doesn't have an onboard DAC so the raw music data should be sent directly to the amplifier in the Meridian system for decoding. 2019 L405 SDV8 Autobiography
Post #531680 21st Oct 2019 3:27pm
gilesharrison
United Kingdom 2008 Range Rover Vogue TDV8 Stornoway Grey
I'm no phone expert, but how can Ann iPhone NOT have an onboard DAC? It is able to play audio through its own speaker.
Post #531722 21st Oct 2019 8:02pm
charlie croker mk2
Yes all devices that convert digital audio to analog Audio must have a DAC that's what DAC stands for, however there are many different types of chipsets and a high quality source connected via the jack as opposed to Bluetooth as Buz is doing will be the most pure available for that type of device .
Post #531756 22nd Oct 2019 7:24am
notty
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Loire Blue
Pragmatically, lossless music (AAC?) at a high bit rate (up to 320kbps) via something like Tidal and using the USB connection should be best.
CD? What's that? Wink
Convenience (and tidal) killed CDs for me a long time back.
And, you know what, try different things out (including the various Meridian DSP settings) and just listen to what you like best and not what "should" be best. Very Happy L405SC just arrived... still working everything out!
Post #531984 24th Oct 2019 12:20pm
Ginja
I've been using my iphone via usb to access my iTunes library which has a mix of apple lossless and mp3 files. I also have amazon music hd which also plays through the usb. Recently though I've lost the ability to access my iTunes library through the screen, or indeed skip files through the steering wheel controls. I've tried a reset, restart and repairing but I only ever get a temporary resolution, music plays but I can only control it through the phone itself. My wife also has the same problem in her evoque. Has anyone else had this and is there a solution? We both have iphone 6s phones.
Post #532556 29th Oct 2019 3:00pm
DrF
Get a blackberry Thumbs Up
Post #532579 29th Oct 2019 7:38pm
awclymm
As above - Tidal - fabulous! 2017 4.4 SDV8 Autobiography
Post #534256 14th Nov 2019 6:33pm
Red Merle
United Kingdom 2017 Range Rover Autobiography SDV8 Aintree Green
Gramophone Thumbs Up
Post #534267 14th Nov 2019 7:49pm
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
In my humble opinion, (and i'm very critical on sound) it very much boils down to the recording quality at source. I have tracks on ipod which sound far better than CD and vice versa. Furthermore, bass and treble often need adjusting accordingly if you're that way inclined.
Post #534278 14th Nov 2019 9:58pm
ilard
That's a very interesting observation, roberlar.
I confess I have been going through a bit of mental anguish. I recently ordered the 1700w, for convenience I will use iPhone and preferably over bluetooth but I wouldn't die in a ditch plugging it in. I didn't specify the CD player. I have tried Tidal but for everything else (basically Bang & Olufson earphones and B&O A8 or something hifi speakers, so not the highest end output) I could not tell the diff between Master and Apple Music. Shoot me. BUT I CAN massively tell the difference between my last car's hifi and what will be my new car's hifi, and it's amazing.... which takes me right back to notty's observation: does it sound right to you?? Answer: yes
So maybe I will not be chasing what is supposed to be the best quality but instead I will be happy if it just sounds punchy and delicious to my old ears (not too old to appreciate Ruff Sqwad's Functions on the Low!). Any audiophile friends can buy their own car. Thumbs Up L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
Post #534285 14th Nov 2019 10:32pm
