Home > Maintenance & Mods (L405) > L405 Batteries how to tell which ones |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7944 |
I have a 4.4 2013 and have 2 batteries.
16th Oct 2019 7:58pm |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 |
Thanks Alistair 2015 4.4 AB
16th Oct 2019 7:59pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35363 |
if you mean that your stop/start doesnt work John then it could be because the aux battery [if you have one] is flat...
16th Oct 2019 8:05pm |
roberlar Member Since: 16 Feb 2019 Location: Buckinghamshire Posts: 203 |
Having had several 'low battery, please start engine' messages over the last few months I bought a new AGM019 battery from Halfords yesterday, , Five year warranty but I want my FBH to work in the coming months ! Not fitted yet but will post any issues |
16th Oct 2019 8:06pm |
Hi Stan , mine doesn't have start stop or atleast it doesnt have the on / off button for start stop and it has never start / stopped aince i got it 2015 4.4 AB
16th Oct 2019 8:09pm |
And just to confirm, my 2013 AB only has one battery and no stop / start |
16th Oct 2019 8:10pm |
so to defo confirm this, have a look behind the panel as in Alistairs pic...if no battery there then you just need the one in the compressor well... ... - .- -.
16th Oct 2019 8:12pm |
Thanks Roberlar, i assume that the single battery is under the spare wheel ? 2015 4.4 AB
Thanks Stan , i will check 2015 4.4 AB
16th Oct 2019 8:13pm |
Dolph, yes one battery only, beneath the compressor. |
16th Oct 2019 8:19pm |
Went and had a look and i appear to have two batteries. On removing the side panel there is an unmarked battery , smallish and i presume a larger one under the spare wheel. My IID tells me 12.0 volts before starting and 14.6 when started. So i need to find out the two batteries that i need.
16th Oct 2019 8:27pm |
Thanks Roberlar , did you check under the side panel on yours ? 2015 4.4 AB
16th Oct 2019 8:29pm |
Stand corrected on that and can only assume a difference 2013 /2015. Hope you source the correct batteries |
16th Oct 2019 8:31pm |
Thanks for your help Roberlar 2015 4.4 AB
16th Oct 2019 8:32pm |
