Home > Maintenance & Mods (L405) > L405 Batteries how to tell which ones
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
As per title, without physical checking ,how do i tell which battery / batteries i have as standard. Mine has no stop start and is a 4.4 AB 2015. Thanks for any replies Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #531163 16th Oct 2019 7:53pm
I have a 4.4 2013 and have 2 batteries.
I think you'll need to check, the side one is dead easy
The main one needs the spare wheel out though
Post #531164 16th Oct 2019 7:58pm
dolph34
Thanks Alistair Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #531165 16th Oct 2019 7:59pm
if you mean that your stop/start doesnt work John then it could be because the aux battery [if you have one] is flat...
...and you need a 90 ah, 850 cca agm battery,
the aux battery is a 70 ah, 760 cca agm ... ... - .- -.
Post #531167 16th Oct 2019 8:05pm
roberlar
United Kingdom 2013 Range Rover Autobiography SDV8 Santorini Black
Having had several 'low battery, please start engine' messages over the last few months I bought a new AGM019 battery from Halfords yesterday, Shocked , Five year warranty but I want my FBH to work in the coming months ! Not fitted yet but will post any issues
Post #531168 16th Oct 2019 8:06pm
dolph34
Hi Stan , mine doesn't have start stop or atleast it doesnt have the on / off button for start stop and it has never start / stopped aince i got it Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #531169 16th Oct 2019 8:09pm
roberlar
And just to confirm, my 2013 AB only has one battery and no stop / start
Post #531170 16th Oct 2019 8:10pm
so to defo confirm this, have a look behind the panel as in Alistairs pic...if no battery there then you just need the one in the compressor well... ... - .- -.
Post #531171 16th Oct 2019 8:12pm
dolph34
Thanks Roberlar, i assume that the single battery is under the spare wheel ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #531172 16th Oct 2019 8:12pm
dolph34
Thanks Stan , i will check Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #531173 16th Oct 2019 8:13pm
roberlar
Dolph, yes one battery only, beneath the compressor.
Post #531174 16th Oct 2019 8:19pm
dolph34
Went and had a look and i appear to have two batteries. On removing the side panel there is an unmarked battery , smallish and i presume a larger one under the spare wheel. My IID tells me 12.0 volts before starting and 14.6 when started. So i need to find out the two batteries that i need.
Ps remove the side panel starting from the back of the rear passenger seat, i almost pulled the grill out trying to pull it by the grill Sad 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #531175 16th Oct 2019 8:27pm
dolph34
Thanks Roberlar , did you check under the side panel on yours ? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #531176 16th Oct 2019 8:29pm
roberlar
Stand corrected on that and can only assume a difference 2013 /2015. Hope you source the correct batteries
Post #531177 16th Oct 2019 8:31pm
dolph34
Thanks for your help Roberlar Thumbs Up 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #531178 16th Oct 2019 8:32pm
