![]() | Home > Maintenance & Mods (L405) > Fuse 63 replacement - How! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35554 ![]() ![]() |
not sure what access is but maybe use a pair of long nose pliers? ... - .- -.
Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369 ![]() ![]() ![]() |
Hi Stan, the access hole is small and number 63 is located between a relay and a large strap connector so it's slightly buried by the surrounding items. Not sure I could get pliers to get a grip the fuse. 2019 L405 SDV8 Autobiography
must be a 'fidlle' job then, unless someone else knows how .. ... - .- -.
are you sure its number 63 and is in fact a fuse? could it be a permanent fuse of some kind?
Mine's a 2013 and doesn't have the front glovebox power socket that the later models have.
i dont have one in the glovebox either [2016] but i do have one next to the cup holders like yours,
andygts Member Since: 16 May 2015 Location: Yorkshire Posts: 363 ![]() ![]() |
You can do it with the fuse puller that is clipped to the fuse board, it's bloody fiddly but can be done, I did mine yesterday.
Definitely number 63 in my manual.
Fuse 63 sits below the red 10 amp fuse shown on the bottom (middle) the photo below
It's 100% fuse 63 on a 2013 and if you are struggling to swap it, that confims it even more. Current
Just ordered some of these. Hopefully they should assist🤞
Fleagle_UK Member Since: 20 Mar 2013 Location: Cheshire Posts: 409 ![]() ![]() ![]() |
holy moly - they look like some medieval torture instrument ! |
The pliers have just been delivered but unfortunately the ends don't close enough to grab the fuse.
this is starting to cost a bit now |
