Home > Maintenance & Mods (L405) > Fuse 63 replacement - How!
Buz1500
United Kingdom 2019 Range Rover Autobiography SDV8 Carpathian Grey
The front power socket located with the cup holders is not working in my car. First point of call was to access fuse 63 in the fuse box behind the glovebox, hopefully this is the correct one.
My question is, how the hell do you get the fuse out? The location for this fuse makes it almost impossible to access with the tool provided.
Help! 2019 L405 SDV8 Autobiography
2023 Defender P400e HSE X-dynamic - gone
2020 Defender P300 SE - gone
2019 Jaguar F-Pace SVR - gone
2013 SDV8 Autobiography - gone
2011 L322 TDV8 Vogue SE - gone
2006 L322 3.6 Vogue Se - gone
1999 P38 4.0 se - gone
199? Classic 3.5 - gone
Post #530402 9th Oct 2019 3:03pm
not sure what access is but maybe use a pair of long nose pliers? ... - .- -.
Post #530406 9th Oct 2019 3:10pm
Buz1500
Hi Stan, the access hole is small and number 63 is located between a relay and a large strap connector so it's slightly buried by the surrounding items. Not sure I could get pliers to get a grip the fuse. 2019 L405 SDV8 Autobiography
Post #530408 9th Oct 2019 3:20pm
must be a 'fidlle' job then, unless someone else knows how .. ... - .- -.
Post #530412 9th Oct 2019 3:33pm
are you sure its number 63 and is in fact a fuse? could it be a permanent fuse of some kind?
just looked on topix and fuse 20 [yellow] seems to be for the front socket, but thats on a 2016 FF as topix doesnt go down to 2013.. ... - .- -.
Post #530415 9th Oct 2019 3:38pm
Buz1500
Mine's a 2013 and doesn't have the front glovebox power socket that the later models have.
I'm assuming that 63 is the correct one as this is shown as the front cigarette lighter in the manual. I can't think where else that could be other than by the cup holders but happy to hear other views. 2019 L405 SDV8 Autobiography
Post #530416 9th Oct 2019 3:45pm
i dont have one in the glovebox either [2016] but i do have one next to the cup holders like yours,
Post #530417 9th Oct 2019 4:10pm
andygts
You can do it with the fuse puller that is clipped to the fuse board, it's bloody fiddly but can be done, I did mine yesterday.
Putting a replacement in is the hardest part as there is no room to unclip the tool, you have to put it in half way then slide the puller off, then push the fuse home. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #530418 9th Oct 2019 4:18pm
Buz1500
Definitely number 63 in my manual.
Number 20 in my manual is the heated steering wheel. 2019 L405 SDV8 Autobiography
Post #530422 9th Oct 2019 5:04pm
Buz1500
Fuse 63 sits below the red 10 amp fuse shown on the bottom (middle) the photo below
Post #530423 9th Oct 2019 5:22pm
andygts
It's 100% fuse 63 on a 2013 and if you are struggling to swap it, that confims it even more. Current
Previous
Post #530424 9th Oct 2019 5:24pm
Buz1500
Just ordered some of these. Hopefully they should assist🤞
[/url] https://abtoolsonline.com/offset-relay-pli...pped-plier 2019 L405 SDV8 Autobiography
Post #530427 9th Oct 2019 5:41pm
Fleagle_UK
United Kingdom 2014 Range Rover Autobiography SDV8 Luxor
holy moly - they look like some medieval torture instrument ! Shocked
Post #530574 11th Oct 2019 11:05am
Buz1500
The pliers have just been delivered but unfortunately the ends don't close enough to grab the fuse.
Just ordered a cheap long nosed plier set, hopefully these will do the job.
https://www.amazon.co.uk/gp/product/B01FUO...&psc=1 2019 L405 SDV8 Autobiography
Post #530576 11th Oct 2019 11:12am
this is starting to cost a bit now Laughing ... - .- -.
Post #530577 11th Oct 2019 11:15am
