![]() | Home > Maintenance & Mods (L322) > Engine flush-would you? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6418 ![]() ![]() |
Nope - for the reasons you found above. Frequent normal oil changes should be done. .
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1800 ![]() ![]() |
Don't use an engine flush (additive)
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Hi Phil,
philip1972 Member Since: 16 Jun 2017 Location: Marval 87440 Posts: 527 ![]() ![]() ![]() |
Hi,
Welcome to the madhouse then, unless this is not your first L322. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8509 ![]() ![]() ![]() |
For sludge and carbon deposits to get stuck in an oilway means they have to pass through the oil pump first, the oilpump picks up oil direct from the filter so there is no way that any deposits can get to a narrow oilway... I have used flushing additives for years in really old abused engines and only seen improvements...
Interesting that the sludge cant block anything!
Fox889 Member Since: 04 Jun 2019 Location: Bury St Edmunds. Suffolk Posts: 696 ![]() ![]() ![]() |
Interesting, as when my fatty went for her first service under my ownership, the much respected Indy put an engine flush through as part'n'parcel of the service. There was no question of 'would you prefer not to sir?' So they're either making a packet out of the treatment or they firmly believe that a flush is beneficial. I'm assuming they know better than me......or I'm gullible.......you choose |
Thats my issue Mr Fox.
I would always take the advice from someone who is more experienced than me.....
It forms in corners of the block where oil usually runs down after being pumped to the top of the engine, the flush thins the oil and washes some of it away, it falls to the bottom of the engine and lands in the sump... the oil pick up for the filter and pump are again, like the petrol tank, above the bottom of the sump so only cleanish oil is picked up, the sludge settles on the sump pan and comes out as you drain it... The small oil ways and galleys that provide oil at pressure to lubricate the crank, cam and other areas only have clean filtered oil delivered to them... Pete __________________________________________________ 2014 L405 Autobiography SDV8 4.4 Loire Blue Ebony interior 2012 L322 Autobiography 5.0 Supercharged Ipanema Sand Sold 2011 L322 Vogue SE 4.4 TDV8 Baltic Blue. Sold 2002 L322 Vogue 4.4 V8 Epson Green (Fatty Offroader) Sold -Click for Project Fatty off roader- |
Grofus Member Since: 24 Mar 2017 Location: Co Clare Posts: 577 ![]() ![]() ![]() |
I always use a pint of diesel in the oil a few days before an oil change. Never had an issue an the new oil stays cleaner for longer. 2007 Vogue TDV8 in Zermatt Silver with Charcoal |
All depends where the sludge is.... .
Well he saw it when he took the cam covers off. |
