Home > Maintenance & Mods (L322) > Engine flush-would you?
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
I had new cam cover gaskets fitted, and at the same time had all PCV pipes replaced, the oil separator and PCV valve.
Garage (a very well respected LR indy) suggested I do an oil flush now and then again in 1000 miles, as there were lots of carbon deposits that he saw when replacing the cam cover gaskets. He showed me pictures and it did look a bot of a mess.
Since then I have done some reading, and there are some opinions that suggest NOT to do it, as it disloges said deposits and you could block oil ways etc.
Any advice suggestion as to whether I should do it?
2004 V8 petrol.
Thanks
Post #529490 29th Sep 2019 4:31pm
Nope - for the reasons you found above. Frequent normal oil changes should be done. .
Post #529495 29th Sep 2019 5:42pm
Mikey
Don't use an engine flush (additive)
But, it's not a bad idea to replace the oil and filter, run for 1k miles, then change the oil and filter again, as a "flush" Thumbs Up
Post #529515 29th Sep 2019 8:36pm
verydisco
Hi Phil,
If your local specialist says it needs too, having worked on your engine, I gather he knows better than anyone here to be fair, but indeed, I would really do the oil change right away and again in 1000 miles - then say every 5/6000 miles max.
is it a new car to you or did you not to oil changes in a while?
If you see deposits, it means the oil has been in there a lonnnng while - your engine does need some TLC ASAP - nice to read you did the pipes and gaskets Thumbs Up l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #529581 30th Sep 2019 3:01pm
philip1972
Hi,
Its a new to me car. I changed the oil as soon as I bought it, and will now do it as suggested above.
The oil in it currently looks good and clean, even after about 1000 miles.
I wonder if the PCV had anything to do with it.
The breather pipes across the top were like putty and rammed full of goopy oil, and the diaphragm was also full of crap.
All these have been changed including the oil separator.
It is now at least breathing like it should!
Post #529583 30th Sep 2019 3:04pm
verydisco
Welcome to the madhouse then, unless this is not your first L322. Thumbs Up Rolling with laughter l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #529584 30th Sep 2019 3:10pm
For sludge and carbon deposits to get stuck in an oilway means they have to pass through the oil pump first, the oilpump picks up oil direct from the filter so there is no way that any deposits can get to a narrow oilway... I have used flushing additives for years in really old abused engines and only seen improvements...
It's the same sort of old wives tale as not letting the petrol tank run low as you pick up the crud in the bottom of the tank... total hogwash, it doesn't matter how much petrol is in the tank, the petrol is picked up from a fixed pipe spaced off the bottom of the tank... no way on earth to drag crud through it more when empty than full...!!!
Just my 2p.... do whatever makes YOU happy... Pete
Post #529715 1st Oct 2019 4:43pm
philip1972
Interesting that the sludge cant block anything!
Thanks for the response.
Post #529721 1st Oct 2019 5:36pm
Fox889
Interesting, as when my fatty went for her first service under my ownership, the much respected Indy put an engine flush through as part'n'parcel of the service. There was no question of 'would you prefer not to sir?' So they're either making a packet out of the treatment or they firmly believe that a flush is beneficial. I'm assuming they know better than me......or I'm gullible.......you choose Very Happy 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
Alfa Romeo Giulietta
Austin A40 Farina MK2
1975 Morris Marina 1.8TC
1973 Honda CB250 K4
Post #529723 1st Oct 2019 5:44pm
philip1972
Thats my issue Mr Fox.
Lots of people say no, but this guy is a real LR expert indy!
Post #529724 1st Oct 2019 5:46pm
Fox889
I would always take the advice from someone who is more experienced than me.....
What would he gain by wrecking your engine? 2012 Orkney Grey Westminster 4.4TDV8 with Ivory interior.........nice!
1973 Honda CB250 K4
Post #529728 1st Oct 2019 5:53pm
It forms in corners of the block where oil usually runs down after being pumped to the top of the engine, the flush thins the oil and washes some of it away, it falls to the bottom of the engine and lands in the sump... the oil pick up for the filter and pump are again, like the petrol tank, above the bottom of the sump so only cleanish oil is picked up, the sludge settles on the sump pan and comes out as you drain it...
The small oil ways and galleys that provide oil at pressure to lubricate the crank, cam and other areas only have clean filtered oil delivered to them... Pete
Post #529730 1st Oct 2019 6:54pm
Grofus
Ireland 2007 Range Rover Vogue TDV8 Zermatt Silver
I always use a pint of diesel in the oil a few days before an oil change. Never had an issue an the new oil stays cleaner for longer. 2007 Vogue TDV8 in Zermatt Silver with Charcoal
Post #529888 2nd Oct 2019 9:31pm
All depends where the sludge is.... .
Post #529909 2nd Oct 2019 11:01pm
philip1972
Well he saw it when he took the cam covers off.
Post #529923 3rd Oct 2019 7:48am
