Home > Technical (L322) > m62 tub 4.4 water cooled alternator flow chart
Pepi
Water cooling on the L322 2004 M62 tub 4.4 alternator !
I know this sound stupid and at first a straight forward thing. I can assure you it is not as the last two L322 have had no obvious return pipe. I have checked the internal drillings and the one at the bottom is blanked off. Can anyone please explain the water flow.
I have checked all the ports and found the inlet goes to the top of the alternator case but try as I might, I cannot find the return.
The bottom situated lower mid case is blanked off the rear of the case is also blanked off.
If this is not the correct can somebody please show me how it should flow🤔 Eddie the eagle watch out 👀
Post #529055 25th Sep 2019 3:04pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi,
There is a port within the recess the alternator sits in. So the coolant flows through the block and then around the alternator, it then leaves the alternator and goes through the radiator.
At least that’s how the coolant flow diagram looks to me but then I can’t see too clearly. I’ve attached a picture of the alternator recess I found on the net where you can clearly see the coolant port on the left and the coolant flow diagram.
Cheers ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #529095 25th Sep 2019 7:49pm
Pepi
Alternator coolant return
Hi Simon
Many thank for coming back to me.
I an in the fortunate position that I have a spare engine that I can get to the water jacket to photograph and check out every orifice. I have check the lower one which appears to be blanked off at the underside of the housing with a brass plug.
The one at the back has an outlet but is capped off with a factory fitted snap connector.
I cant see any sign of any others. I have cleaned the surface around where you thought it to be but U cant see anything.
I an sort if thinking that the rear port should have some sort of either flow or return pipe connected to it.
But I cant find it on any diagrams or parts manual.
I has got me stumped 🤔
Picture orientation!
The bottom of the pictures is to the right hand side of the page.
Post #529140 26th Sep 2019 11:08am
UK Marine
Hi,
I think that that alternator housing has been tinkered with. There is an inlet at the back of the housing and the connector at the front is the outlet or vice versa Whistle
Here is a video of someone having Vanos troubles but thankfully the camera angle is perfect for looking into the alternator housing.
Simon
Post #529146 26th Sep 2019 11:36am
Pepi
Alternator water flow
Hi Simon.
On your car where does the rear hose connect to please? Eddie the eagle watch out 👀
Post #529147 26th Sep 2019 11:46am
UK Marine
Hi,
Is yours like this?
Simon
Post #529150 26th Sep 2019 12:16pm
Pepi
Timing case
I would imagine it it will be.
It looks from that as though the lower outlet is the outlet via an internal feed back up to the water pump or Thermostat housing. Eddie the eagle watch out 👀
Post #529156 26th Sep 2019 12:31pm
UK Marine
I’m thinking along those lines as well. But I’ve just read up on how to remove the alternator casing and it doesn’t mention any o rings or coolant gaskets other than the o ring for the alternator.
So back to your original question - coolant flow. It looks like coolant comes in but doesn’t actually flow anywhere, except in this picture it looks like a gallery in the casting leading up to the block away from the alternator housing. Is it possible for you to have a look on your spare engine and possibly take off the alternator housing, it’s 15 bolts I believe.
Simon
Post #529157 26th Sep 2019 12:43pm
p38arover
Australia
I never thought to look when I replaced my alternator a few months back. Crying or Very sad Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #529158 26th Sep 2019 1:15pm
UK Marine
If that cap is there it’s just another potential leak point.......... Big Cry ______________________________
Simon
Post #529164 26th Sep 2019 2:13pm
Pepi
Cap ?
Hi Simon
Thanks for your input.
Which cap are you referring to please? Eddie the eagle watch out 👀
Post #529220 26th Sep 2019 10:01pm
UK Marine
The one in the picture of the rear of the alternator housing. It’s the black plastic cap with a wire clip keeping it in. ______________________________
Simon
Post #529258 27th Sep 2019 9:18am
Pepi
Cap
Right got you!
Never had a leak from there so far but it seems a little strange they have not used it as a return feed!
Anyway we seem to have solved that one now.
I had asked several dealers if they knew and it seemed to confound them also.
Thanks for that Simon
Kind regards Pete
PS did you get your suspension alinement sorted? Eddie the eagle watch out 👀
Post #529263 27th Sep 2019 10:25am
