Home > In Car Electronics (L405) > 360 camera module location help needed
Charles89
United Kingdom 2014 Range Rover SVAutobiography SDV8 Scotia Grey
Hi all,
Urgently need some help in locating the camera module on my L405 2013... all I could find online was a reference to it being behind the passenger seat...
I think it may be in the floor under the seat.
If anyone can source a wiring diagram or exploded view I'd be grateful.
Had intermittent camera issues for ages now, 4 new cameras later, it's still intermittent
Kind regards
Charles
Post #528751 22nd Sep 2019 6:01am
Charles89
Bump
Post #529007 25th Sep 2019 6:14am
is this any help charles,
Post #529012 25th Sep 2019 7:52am
Charles89
Stan you sir are a gent!
Much appreciated, it certainly helps... if only I knew how to remove the rear seat to access it now Big Cry
I thought it was under the passenger seat, but it looks like it's under the rear bench seat.
I previously had the rear boot side panels off and it was not in there. I did have a chance to admire the engineering of the entirely stand alone HVAC system for the rear passengers. I didn't realise it was a complete unit with its own matrix and AC condenser etc. No wander the AC is outstanding in the car Smile
Post #529037 25th Sep 2019 11:22am
andygts
This may help, pdf of the fault from TOPIX
https://www.google.com/url?sa=i&rct=j&...2705748007 Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2013 Range Rover Autobiography SDV8
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #529045 25th Sep 2019 1:04pm
nice one andy...looks like the module is in/on the door pillar.. ... - .- -.
Post #529046 25th Sep 2019 1:14pm
Charles89
Thank you both. Very very much appreciated. I now have all my cameras working again! Very Happy
It was behind the trim next to the rear seat, that required 2 8mm bolts to be removed, and then the leather stitched pannel can be removed. Took all of 10mins + my OCD leather cleaning of course.
Cant believe I've paid landrover £1860 so far to replace all of my cameras and then tell me there is a wiring fault and the whole loom needs inspecting, and all it took was a new module.
One very happy happy with fault free camera systems
Thanks again Thumbs Up
Post #529089 25th Sep 2019 6:31pm
good result Thumbs Up ... - .- -.
Post #529092 25th Sep 2019 6:44pm
andygts
I'd be going back into Land Rover and speaking to a manager armed with the Special Service Message Bulletin, it's a known fault hence the service bulletin, they should have gone straight for the module. It is not even model specific so the techs should have encountered this fault before. I'd be wanting some money back. Current
Previous
Post #529141 26th Sep 2019 10:14am
tonypjr
United States 2015 Range Rover 5.0 SC V8 Fuji White
I haven't had this issue with my L405, but did have it with my L320. I ended up fixing it by unplugging all of the cameras at their individual locations, cleaning the plugs with isopropyl Alcohol Spray with a plastic bristle brush and putting a light dab of lithium grease. After that, I never experienced another Flicker or pink screen from any of the cameras. I think the connectors don't really seal very well especially in climates where we have snow and lots of water. Hope this helps. Free99 is always a good thing.
Post #532597 29th Oct 2019 9:49pm
