![]() | Home > Maintenance & Mods (L322) > Left Turbo failed and cylinder 8 injector |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
Is the 2k you have been quoted fitted? 2015 4.4 AB
Ifty Member Since: 17 Mar 2018 Location: Dudley Posts: 16 ![]() ![]() ![]() |
YES
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1800 ![]() ![]() |
Your indy is correct. Recon turbos are very hit and miss when it comes to setting up the actuator. Just 1mm in either direction will cause problems, and it snot an easy job to access and move them
He did recommend if I wanted to go down the recon route then to try Telford turbos. Have you guys had any experience with them or do I have to get new ones. |
Just from my own experience ( certainly not an expert), i had 2 recon turbos fitted to my 2007 3.6 TDV8 at 180k kilometres , then had remap and part exed it at around 260k kilometres ( its still.going strong). 2015 4.4 AB
Is fitting turbos a hard job as YouTube videos say the body has to be separated from the chassis |
Thats for the sport. People on here have done them themselves but when my indie did mine he dropped the engine. 2015 4.4 AB
Nick591 Member Since: 04 May 2017 Location: Seaton Dalaval Posts: 193 ![]() ![]() |
My understanding is that it is really not feasible to replace LH turbo without dropping whole engine/gearbox/transfer box assembly on subframe out of the bottom of the car. RH one I believe can be done in situ but it is time consuming and awkward.
That’s what my Indi is saying. Lots of smoke from left exhaust which clears after engine is warm unless you rev it and it says engine system fault. I know one injector is defo gone and he said egr valve needs replacing |
I would start with getting injector and EGR replaced then see. Much simpler jobs. Turbo faults with 'lots of smoke' due to failed seals don't usually stop when engine warms up . Did it happen suddenly? Can you get the fault codes read and post them on here. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
I have the fault codes please see attached.
I've replaced TDV8 turbos at the roadside. It is a very time consuming, and fiddly job, but doable |
Can't see any fault codes using Tapatalk on my phone. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8 |
If you click on my gallery then you should be able to see them |
