Home > Maintenance & Mods (L322) > Left Turbo failed and cylinder 8 injector
Ifty
Hi Guys
I need some advice. My 2007 3.6 V8 RR Vogue is in the garage with a left turbo failure, injector and egr valve replacement. I have been told it is £4000.
My indi said he will replace both Turbos and will not touch recon turbos and I will have to take car somewhere else. I don't have £4k lying around.
Any Ideas where I can get this done cheaply but properly. I have been quoted £2k from a turbo recon garage.
Help please as I really love the car. Car is in Wolverhampton at the moment but I can get it delivered to a place u guys recommend
regards
ifty
Post #528652 20th Sep 2019 8:34pm
dolph34
Ireland 2015 Range Rover Autobiography SDV8 Corris Grey
Is the 2k you have been quoted fitted? 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #528653 20th Sep 2019 8:39pm
Ifty
YES
Fitted with Recon turbos but not injector EJR valve
Post #528654 20th Sep 2019 9:04pm
Mikey
Your indy is correct. Recon turbos are very hit and miss when it comes to setting up the actuator. Just 1mm in either direction will cause problems, and it snot an easy job to access and move them
FWIW, I will only entertain fitting brand new OEM turbos...
Post #528657 20th Sep 2019 9:43pm
Ifty
He did recommend if I wanted to go down the recon route then to try Telford turbos. Have you guys had any experience with them or do I have to get new ones.
Post #528658 20th Sep 2019 9:50pm
dolph34
Just from my own experience ( certainly not an expert), i had 2 recon turbos fitted to my 2007 3.6 TDV8 at 180k kilometres , then had remap and part exed it at around 260k kilometres ( its still.going strong). 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #528660 20th Sep 2019 9:53pm
Ifty
Is fitting turbos a hard job as YouTube videos say the body has to be separated from the chassis
Post #528662 20th Sep 2019 10:03pm
dolph34
Thats for the sport. People on here have done them themselves but when my indie did mine he dropped the engine. 2015 4.4 AB
GSXR 1000 K5
R1 1998
Post #528663 20th Sep 2019 10:05pm
Nick591
My understanding is that it is really not feasible to replace LH turbo without dropping whole engine/gearbox/transfer box assembly on subframe out of the bottom of the car. RH one I believe can be done in situ but it is time consuming and awkward.
Neither is really a DIY option without a vehicle lift and very good toolkit and skills.
What are your car symptoms, are you sure the turbo has gone? Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #528721 21st Sep 2019 4:13pm
Ifty
That’s what my Indi is saying. Lots of smoke from left exhaust which clears after engine is warm unless you rev it and it says engine system fault. I know one injector is defo gone and he said egr valve needs replacing
Post #528726 21st Sep 2019 5:03pm
Nick591
I would start with getting injector and EGR replaced then see. Much simpler jobs. Turbo faults with 'lots of smoke' due to failed seals don't usually stop when engine warms up . Did it happen suddenly? Can you get the fault codes read and post them on here. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #528728 21st Sep 2019 5:14pm
Ifty
I have the fault codes please see attached.
I have now added the fault codes I think
Post #528729 21st Sep 2019 5:22pm
Mikey
I've replaced TDV8 turbos at the roadside. It is a very time consuming, and fiddly job, but doable
Post #528745 21st Sep 2019 10:19pm
Nick591
Can't see any fault codes using Tapatalk on my phone. Previously a 2008MY Tonga Green Vogue SE 3.6 TDV8
Post #528807 22nd Sep 2019 11:27pm
Ifty
If you click on my gallery then you should be able to see them
Post #528811 22nd Sep 2019 11:45pm
