Home > Technical (L322) > Radiator/Cooler in Drivers Side Wheel Well
beep-beep
Ireland 2007 Range Rover Vogue TDV8 Buckingham Blue
Fixing my range rover which had some damage, and there is just in front of the wheel that got a slap. It is a 3.6 09 Facelift version, but unsure what the rad or cooler is for.
Any help greatly appreciated!
Post #528545 19th Sep 2019 3:48pm
oil cooler me thinks ... - .- -.
Post #528551 19th Sep 2019 5:00pm
Jamiehol
United Kingdom 2007 Range Rover Vogue TDV8 Stornoway Grey
It is an auxiliary radiator for the cooling system, think a new one is about £270 from Land Rover in the UK.
Post #528553 19th Sep 2019 5:34pm
not oil cooler then Crying or Very sad ... - .- -.
Post #528554 19th Sep 2019 5:40pm
Jamiehol
No although I am sure I have seen diagrams saying it is an oil cooler.
The top feed off it come from the large metal pipework that runs to the bottom of the main radiator it is often this hose that rubs through on the header tank bolts. The bottle m hose of it travels on the side of the radiator and connects to one of the hoses near the top of the radiator.
Post #528591 20th Sep 2019 5:57am
S.Hafsmo
Norway 2007 Range Rover Vogue TDV8 Orkney Grey
Due to package constraints an auxiliary radiator is required to maintain acceptable coolant temperatures under arduous driving conditions such as high-load and high ambient temperatures. This radiator is located in the in the RH wheel arch area, with cooling airflow supplied by a dedicated aperture in the front bumper. The auxiliary radiator is connected in parallel with the main radiator, with the coolant flow being controlled by the main engine thermostat. 2007 L322 3.6 TDV8 Stornoway
Post #528598 20th Sep 2019 8:34am
beep-beep
Cheers gents! Was pretty sure it was the AUX heater but wanted to double check!
Post #528607 20th Sep 2019 9:23am
